Clamshell Batteries
otobmark
NC
Any downside to using disposable Lithium AA batteries other than cost? Do they handle the drain?
n7maq-1
Oregon
The clamshells that I see normally specify Alkaline cells only. There is a slight voltage difference and when you are putting in 10 to 12 batteries .2 or .3 volts will add up.
otobmark
NC
I considered that. The counter argument is that since the normal rechargeable battery for the radio is lithium and we all know that the lithium batteries sweep a pretty wide voltage range as they go from full charge to low I was thinking the radio is built for non critical voltage.
