CLEMARS 1 voice inversion usage?
RolnCode3
Sacramento/Bay Area, CA
OK, well, I was going to post about Cal Expo PD using voice inversion. However, I just realized the frequency I'm asking about is Clemars 1. Sounds like someone is using voice inversion (or something else) that turns human voices into gobbeldy gook. Anyways, anybody know who in the Sac area is doing this? Just curious.
154.92
OpSec
All your WACN are belong to us
Monitoring the database
I'm just starting to learn what's what out there, but isn't CLEMARS a mutual aid channel?
Voice inversion on a M/A channel is not a normal thing...
RolnCode3
CLEMARS and Calcord are definitely M/A / Interop. I haven't heard any voice inversion on Calcord (in fact I hear almost no traffic on it here), but I'll have to listen to it a little better. Could be some State DOJ guys or something, although they have their own channels.
I did hear one narc guy here in Sac referring to some out of area guys using a Cal-MMET channel (major methamphetamine enforcement). No idea what that is, but could just be a M/A with encryption/voice inversion.
Tweekerbob
This is being used by some agency (probably other than DOJ-they use 154.680) for narcotics surveillance. They also utilize a helicopter.
My guess is SSD, but not really sure. You can hear just a bit of the "unscrambled" transmissions on that freq I told you about, Bill - 132.125 AM. Every once in awhile, these transmissions are NOT scrambled. In fact, I have this programmed in my scanner and heard for the last 2 weeks unscrambled drug surveilance (i don't know how to spell) on CLEMARS. It seems to be centralized over Sac, but I have heard them as far away as Willows to Stockton.
Ryan
SAR923
I have heard the same traffic over here on CLEMARS although not on on CALCORD. From the unscrambled traffic I've heard, it is state DOJ agents working with what sounds like DEA agents on a drug case with a lot of code-5 activity including following vehicles with a helicopter. This has been going on for about a week. I don't know what they are using for encryption but it's not the same system as the encryption system used by our department since I still get them scrambled even in the scramble mode on our radios.
Norman
N CA
Ramsey Electronics makes a Speech Scrambler-Descrambler kit :)-
Do a Google search. Norm.
kma371
Yes, it is probably the DOJ-BNE guys. In Contra Costa Co., whenever they get interference from 154.680 they switch to CLEMARS (VHF) or CALCORD. I have a DOJ-BNE channel list at home. I will post it after I get home from work.
-Bill
selgaran
CM98dn
Been hearing it on-and-off on CLEMARS for the last couple months in Yolo also. In the past, I've heard various surveillance on CLEMARS in the clear by BNE or whomever, so I suspect they finally got smart (or got new radios) and started scrambling.
I'm surprised if they are using CALCORD - that's supposed to be the "California On Scene Coordination Channel", for interagency communications at the scene of an incident, not for wandering around the countryside following some nitwit. Most agencies around here use it for air-to-ground for medical helicopters.
kma371
this is what i have for the DOJ-BNE folks
ch 1 154.680 pl in 94.8 pl out 94.8 (mt diablo area)
ch 2 154.680 pl in 110.9 pl out 94.8 (el dorado area)
ch 3 154.680 pl in 127.3 pl out 94.8 (mendocino area)
ch 4 154.680 pl in 146.2 pl out 94.8 (sonoma area)
ch 5 154.680 pl in 167.9 pl out 94.8 (santa clara/butte area)
ch 6 154.680 pl in 192.8 pl out 94.8 (calaveras area)
all of the above are repeaters, input is 155.460
everything below is simplex unless otherwise noted
ch 7 154.680 pl 94.8
ch 8 154.665
ch 9 154.695
ch 10 154.920 clemars 1
ch 11 154.935 clemars 2
ch 12 156.075 calcord
ch 13 155.475 nlemars
ch 14 154.905 chp extender
ch 15 154.995
ch 16 155.040
ch 17 155.445
ch 18 155.460
ch 19 155.505
ch 20 155.595
ch 21 155.625
ch 22 repeater in 156.180 repeater out 151.115 pl 156.7 fresno/madera
OpSec
Norman said:
http://www.calsiec.org/products.html Some good info from CA OES. Calcord is for emergency use only and voice privacy is not authorized. I have heard this type of traffic before on Nalemars (155.475) Norm.
That is a very informative read...thanks for the link. It helps in future programming for me, and I passed along the link to a few people in charge of a similar program here.
