SDS100/SDS200: Close Call DMR Color Code decode issues
WadeBlake
Sherwood, OR
When I use Close Call for DMR frequwncies with known Color Codes, the SDS100 does not display the correct color code. For example, known color code is 1, SDS100 displays 15 or 10 for color code.
Anyone else notice this issue?
Thanks, Wade
phyberoptics
Orangeville, Ontario
Close call does not work reliably for DMR if you’re trying to capture the radio rf output, because the radio only uses one time slot at a time. Close call can’t latch on because the sampling isn’t large enough due to the “pulsing”. CC does capture repeaters because repeaters transmit both timeslots.
