My mistake. They removed that option in the X model as it was not a useful function. So one less thing that could be wrong. Check that bandplan are set properly by entering the closecall frequency that ends up as WFM by manual entering it by hold+frequency+hold and see what the modulation type are displayed as. If it's WFM then the bandplan setting needs to be edited in the Settings menu.
/Ubbe
Now that is interesting. I did as you said, press hold-enter frequency-press hold again. Yours is the only solution that seemed could be worth checking out mentioned so far except the posters who told me to do what I've already done.
The frequency I entered is 122.800 which should obviously be AM, instead it shows up WFM...
I'm stumped because under the band defaults under settings that frequncy range is defaulted to AM and 8.33 KHz deviation.
I've already checked and rechecked and there is NO band in my default band plan set to WFM mode.
How in the world is close call getting that freq as WFM?
I may have just fixed the problem. the WFM under the frequency was flashing so I pressed function then 9 (Modulation) and changed it to AM.
I just tried to reenter that frequency and this time it shows up as AM under it and not flashing.
Also tried hold plus other aircraft freqs then hold again and they all show up AM.
Also entered a 153 MHz freq in that same manner and it shows up as NFM, EXCELLENT!
I'll report back as soon as another close call hits and let you know if it's fixed now.
Thanks for the help, I've a feeling that you have solved this thanks!
