OP25 Close OP25
veceme
Hello everything is fine? I would like your help. How do I close the software terminal without this message appearing:
there is still a process running in this terminal. closing this terminal will kill him.
Because I forced it to close and dive to format it again, as it did not accept opening with the command ./rx.py --args 'rtl'...... always an error.
The terminal doesn't give me the option to close
Thank you for your help and I look forward to it.
lwvmobile
DSD-FME
Also, should probably mention, only use ctrl+c if the (q) key doesn't work when trying to close OP25 in case of something on the back end hanging up or crashing. I think its the (q) key. If you use ctrl+c to close when the ncurses terminal is open and it garbles your console terminal, then you can use the 'reset' command in the terminal (even if you can't see it being input due to corruption) to reset the terminal and have it refresh properly.
veceme
Understood, I will follow these steps. Again thank you very much for the help.
boatbod
Talbot Co, MD
"q" is indeed the preferred way to quit the curses terminal and shut down op25
The http terminal doesn't have that feature so the only option is to ctrl-c it.
wgbecks
NE Wisconsin
Here's another thought. Unless you're only interested in running op25 on demand but would prefer to run op25 more like a scanner,
then it makes more sense to set it up to run as a system service as opposed to manually starting and stopping the application. The same
applies if you're using Liquidsoap in conjunction with op25.
The README-rpi3-liquidsoap found in ~/op25 has instructions for setting op25 up to run as a service and would only
require minor editing of the two included service files to reflect a different user login.
veceme
Yes really. As I've been told, it's happening.
Thank you very much.
