Coastal Bend P25 Phase received on Kleberg System?
scanthewaves
Texas
Is there some reason why I'm receiving the Coastal Bend P25 Phase 2 system TGID 2074 That's Patrol 2 Delta on the Kleberg P25 Phase 1 system on my 436hp Is this some kind of simulcast or interop?
rattlerbb01
TX/LA Database Admin
Boerne, Texas
Interop is possible. You are sure it is on the Kleberg reported frequencies?
851.050
851.400
852.050
852.400
853.050
It’s possible that they merged to the Coastal Bend system. Check it out in your “Analyze” feature and see what Sys ID and WACN are coming up on the 436HP. If it still says 00A-92579 then no it is still standalone. But if the WACN is 46FEA on Kleberg frequencies, then they would have merged.
nueces162
Corpus Christi TX
And several of the Kleberg groups, SO dispatch and a couple in the low 45000 group range that are not in the DB and I cant tell what they are yet, have been showing up on the Shoreline and Violet sites here in Nueces County the last few days - I'm too far off to get the Kleberg site to check it but was wondering if any CCPD groups were showing up down there
rattlerbb01
Boerne, Texas
Based on that I would say they are on the Coastal Bend core now, will see what his findings are with the control channel analysis
ralexander5
Mathis, Tx
Kleberg County site is now P25 phase 2 on the Coastal Bend system WACN 46FEA 57 61.61. Unfortunately with the switch some TGs are at least partially encrypted now. Kingsville PD and TAMUK PD are showing up encrypted on Robstown site. Will be submitting changes to database.
rattlerbb01
Boerne, Texas
Kleberg system has been deprecated, Coastal system updated. Is the EDACS system offline everywhere now?
scanthewaves
Texas
Oh well it was nice while it lasted.
scanthewaves
Texas
851.050
851.400
852.050
852.400
853.050
I totally forgot about this post and just remembered it, looks like the mystery has been solved and I'm not too happy with the findings but it is what it is.
fire1429
texas
Question?? is the kingsville and fal towers up and running? I had those towers programmed in my G5 while passing through kingsville and it only connected to the robstown tower. I pulled all the information from the RR database “coastal bend p25”.
rattlerbb01
Boerne, Texas
Kingsville was a neighbor to several sites when I was down there a couple weeks ago, but I couldn’t receive it from Port A.
fire1429
texas
Figured out what was wrong and why the G5 wasn’t picking up the kingsville site. when uploading the information into the unication pps it put the system ID as 169 for the kingsville site instead of 057. Made the small change and got to receive the kingsville site and also the Falfurrias site while passing threw.
