Coax Arcing
HOGMOA
Shell Knob
During Thunderstorms, I disconnect my Disc Cone Antenna from the scanner. When it was disconnected, I kept hearing a pop similar to the sound heard by a spark plug arc. What can I do to make sure that my kids/me and other things are not in danger from this. (I put the connector down in a glass jar. Not sure if this was a good thing...But I did it)
jazzboypro
Laval
You mean that the sound comes from the coax ?
nd5y
Wichita Falls, TX
The coax or antenn are not grounded properly. The glass jar thing is a stupid CB myth. What do you think will happen if the voltage builds up high enough to arc through or around the glass?
HOGMOA
Shell Knob
Well, thought it was a good thing. Not meant to be considered stupid.
Not stupid, but it is a common myth repeated through the hobby. Static electricity is one concern, direct and even nearby lightning strikes is another. A glass jar will not protect.
If it's your only option, the best bet is to chuck the coax entirely out of the house. That can reduce risk, but will do nothing to protect you, your home, your radio if you aren't home to do it.
HOGMOA
Shell Knob
Mast.jpgThis is the mast I am using. It is mounted to the side of my home. The ground surface for 10' from the Condo is Asphalt and the house surface is wood. So, my question is, how do I ground it safely without having a wire which might not have (as I am not a radio tech) enough insulation to prevent arcing through the insulation and causing a fire in the wood. Ideas please. Just want things Safe. I have a 50' Coax to the back of the scanner and don't want to cut that if at all possible.
HOGMOA
Shell Knob
The Coax is routed through the wall. Damn this is concerning.
Being in a condo complicates the issue.
A professional/licensed/bonded electrician is the answer. And yes, that costs money.
The PDF I linked to covers it all. Well, "all" in the sense of meeting NEC. Read through that and ask your questions.
HOGMOA
Shell Knob
Thanks so much.
HOGMOA
Shell Knob
Thanks,
I contacted a buddy who is a Licensed Electrician and one thing he said was to get rid of the steel extensions I was using and use schedule 80 PVC for the 6' mast. He then said get a surge protector and attach a bare copper wire to a copper grounding post driven into the ground. So...there is my start.
