PVC electrical conduit. Looks like PVC water pipe, but instead of being white, it's grey.
Yeah, what he said^
If you are going to run all new cable, get the direct bury rated stuff. It'll last longer. Times-Microwave LMR-400DB. Eventually, may be several years into the future, the jacket will break down on the other stuff and your coax will fail, even if in conduit. Any water that gets in might contain chemicals, fertilizer, oil, all things that can break down the jacket.
Also, go larger than you think on the conduit. While you may be able to get LMR-400 into 1/2" PVC, it's going to be a pain to pull. The real labor/cost is in digging the trench. Lay in something bigger in case you ever decide to add more coax. Last time I did this, I put in 2". Didn't cost that much more, and the shovel made the trench plenty wide enough.
