SDS100/SDS200: Colder temps freezing part of keyboard
NS9710
Niagara Falls, NY
I am playing around with my SDS100, and I noticed when running the AC, and such, the 1,4,7, No/Priority, and Avoid keys stop responding, but once the temperatures warm up, the buttons return to being able to respond normally, is there any way to counter this issue without needing to send it in for repairs at Uniden?
jtwalker
Is the a/c blowing directly on the scanner? Are there icicles forming on/around the scanner?
The only way I see this being an issue is if the scanner and the air surrounding it are very hot and humid and then cool air causing condensation inside the scanner.
NS9710
Niagara Falls, NY
None of that, but the case gets a tad cooled off and then the buttons go non-responsive
NS9710
Niagara Falls, NY
I also want to add to the factors, that the SDS has never had any liquids subjected to it, and I always took extreme care not to allow any moisture of any sort to get into or onto the scanner. Thus my confusion why it’s happening now after almost 4-5 years I think. I bought it used from a member here when we got our first stimulus check under the Covid issues.
donc13
Grand Junction, CO
Does the a/c blow directly on the keyboard, in particular the left front of the radio where those keys are?
My thought is that there may be an alignment issue or rubber stiffness between the keyboard and the contact(s) that gets closed.
NS9710
Niagara Falls, NY
It doesn’t, I also don’t feel any stiffer than the others, and they all respond the same way, this is even more confusing the further that we go into it
