Combining Feeds
jwh1972
First I'd like to thank everyone for providing the feeds on this site.
I live in an area of Pennsylvania that is located on the corner of three seperate counties (Carbon, Schuylkill, and Luzerne). I am wondering if there is a way to combine the seperate feeds from these counties into one feed. For instance combine the following feeds: 1) Carbon County Police, Fire and EMS, 2) Schuylkill County Police Fire and EMS, & 3) Hazleton Police Fire and EMS and Hazle Township Fire and EMS.? I realize I'm probably asking for a lot. But I thought I'd ask if there is a way to do it.
Thanks, John
Tweekerbob
Regardless of the technical issues, this won't happen. But there are at least three possible solutions to your dilemma:
1. Some media players, like Winamp and VLC, to name a few, can have multiple instances open at the same time. Each instance can listen to a different feed running through the same soundcard, giving you, the listener, the same effect as if someone combined all three feeds on the server end.
2. Try a program called ScannerLive. There is a free demo and some demo videos there. It will allow you to monitor up to 10 different feeds concurrently, and acts like a scanner...stopping on the active feed and muting the others. Then it moves on to the next active feed and so on. It's free to try and $20 to buy. The author frequents these forums and is very helpful.
3. You can move farther into your county so that the other counties will seem too far away to care about :)
W8RMH
Feed Provider Since 2012
Thanks, John
All that one one feed would make it impossible to follow, especially for a newer listeners.
jwh1972
Thanks for your help. I will check out that software.
cavmedic
Pottstown Pa
You could always run your multiple scanners into an external mixer board , thus combining the signals to one output that feeds the input to your soundcard.
