Computer programing
teufler
ST PETERS, MISSOURI
yes it is, a special cable that comes wiith the scanner , serial to mini usb, or you can use a usb to serial converter, or there is a usb cable that runs usb to mini for the radio. This is asn optional cable from Uniden, runs $29.95
N0GTG
Scanner programmer since 1997
Denver, Colorado
You could also use FreeScan, which I use, available from FreeSCAN - Sixspot Software. It will read/write to 11 scanners, including both your 396T and 396XT. You could read the T, and write the file to your XT. Can't get much easier. If you like it, you could make a donation to the author (I have no connection to the company).
RWPowell2
Cypress, CA
Try the DB9 Method
Guess I'm old fashion because I use DB9-pin males connected with 2-conductor shielded cable to remote control my BCD996XT's. DB9's are readily available in any electronics store. I do have a bunch of USB cables that I bought at the 99 Cent store and have thought about cutting one end off and soldering on a DB9M. This would be helpful to use with newer computers that don't have the DB9 Serial Port. The other advantage is you don't have to open Device Manager to program the serial port because USB does this automatically. If you do use a DB9 cable, insure the pins 2&3 are reversed at one end (null modem), otherwise it will not work.
wbaker121
I can't get the software to work on my MacBook Air. I downloaded software, bought the USB cable and I'm stuck....
San Diego, CA
wbaker121
You don't mention software. ProScan and Freescan are Windows only. You'll need Parallels on a Mac to run them. (While I have a Macbook, I seldom use it and don't have Parallels, so my opinions are from what I've read, not what I've done).
Neverpanic1
Odessa, Texas
Ordered the cable and trying tomorrow. I'm trying on my step-daughter's PC, as I own a Macbook Pro. I received my scanner as a Father's Day gift and still pretty "wet behind the ears" on scanning. I had a conventional scanner about 15 years ago, but have since lost touch.
Please wish me luck !
teufler
ST PETERS, MISSOURI
file
here is a file you may use to get started on odessa, Texas. Its a Freescan file, zipped per RR requirements. Depending on your antenna, you hay go for further out counties After the computer recognizes and assigns you a comport, install the file..
  • odessa midland.zip
Neverpanic1
Odessa, Texas
lost...
Well.....i give up. I'm guessing I'll just ship off to get my scanner programmed. I had ordered the USB cable for it. Tried the freescan and the download forwarded to me, but I'm guessing I'm not too savvy on this..
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Neverpanic, this article from our wiki (anything that's blue is a link) has links to just about everything you need to know about how to get started programming these Uniden DMA scanners...
Program your DMA Scanner - The RadioReference Wiki
At the bottom of this article are links to the Easier to Read manuals. Click on the link for your radio.
Between this and the Trunking basics article (also linked in the above page, and a subject that many find a little daunting at first) you should have more than enough to get started. Be sure to bookmark this article - likely you will come back to it again
Mike
