Connect System CS 580 Antenna
blackbelter
Are there any suggestions for a better than factory antenna for this DMR radio ? The enhanced antenna should have the same thread type of the radio . I would also appreciate any suggestions on a connector thus I can use my Diamond SRH77CA with it .
jaspence
Michigan
If you use the Diamond antenna, be careful if the antenna is much longer or heavier. The adapter length will also add stress to the connector and can cause damage to the soldier connection or physical connector on the radio.
The connector you need on the antenna is a SMA female type. Check the online specs for the Diamond connector type, as I do not have one to verify the type.
blackbelter
Thank you , I am trying to determine the type of the radios EOM antenna tread type .
icom1020
I use the Nagoya 701 series and the thread depth appears to be the same. I can't tell much different with the stock antenna, however. Don't have a mono band antenna in my stash to compare right now.
blackbelter
Thanks, I was thinking about purchasing the NG 771. Anyone uses this antenna for the CS 580?
tweiss3
Is it time for Coffee?
Ohio
I have used the 701 and the 771. Both work well, but the 771 is extremely long. If the radio is going to be a desk/cradle queen, its fine, but if you are going to carry the radio and put it on your belt, it is way too long.
blackbelter
Thanks,I tried the NG 771 and the results were no better than the factory antenna .I retuned the antenna .
k4do
VSWR is the only answer. Even Diamonds for the ham band have VSWRs greater than 2. In my opinion an antenna with a VSWR greater than 1.5 is junk maybe tunable though.
