D
DaveNF2G
Guest
IP is M/A-Com's way of sneaking around the "interoperability" issue. If the system can be linked to another system at the back end by using some sort of networking, then they can claim that it is interoperable.
It should also be noted that NY and PA systems are different enough that they are NOT compatiable. That tidbit comes direct from the M/A Com rep on the NY project.
I think it would be a good idea if the Fed were to set a policy where agencies are only eligible to receive federal funding for their radio systems if they go with P25 or another federally accepted radio system type
which satisfies federal requirements for cross-platform, cross-brand compatibility.
Nobody would be FORCED to go P25, but if they did, the fed would help foot the bill for it. ENCOURAGE
interoperability without making it compulsory.
Elroy
I'll say it again...on our domestic borders:
Connecticut.....Motorola P25 trunked
Massachusetts.....Motorola P25 trunked
New Jersey.....Motorola Type II Analog
Vermont.....Standard UHF analog
Am I missing something here?
The next step would be for the FCC to refuse to certify non-P25-compliant systems and equipment for public safety use.
You're not seriously suggesting that the solution to interoperability is to just give everyone a multi-band, field programmable radio, are you? Do you realize the logistical nightmare that would create? .
Except The FCC does not certify equipment for "public safety use".:roll:
Got more important things to worry about than what frequency/PL/offset we need to program into the radio in order to talk to so-and-so.
It's also a lot easier for them to train a few pilots and crewmembers in the use of the radio, as opposed to thousands of first responders.
They could if they so chose. The enabling legislation permits such policymaking by the Commission.
How are they going to do that?
Move "public safety" out of Part 90 and into a new part?
How do you define "public Safety radios"?
