Control Channels .CSV Import
2wayfreq
NM Kirk City
I am trying to add Control Channels to my G4. I set the spreadsheet to .csv and try to import it but it says its the wrong format. What fields is it looking for?
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
It may depend on your specific version of PPS.
Do you have any sites already set up? Export one of those to CSV and use that format.
If you don’t have one to export, reply back and I will export one from PPS 0.4.0.41.
Importing from a CSV file isn't an option from what I see. If you read the option it is "import from a Radio Reference CSV" which needs to be downloaded from the database, but I believe only premium members are allowed to download files.
hazrat8990
Wyoming
In order to get the correct format you'll need to export your file first. Just be sure to send it somewhere easy like the desktop, make all of your changes, and then import it back into PPS. The first row is what needs to be perfect, or else it throws the earth out of orbit. This is by far the easiest method since PPS is rather clunky.
