SDS100/SDS200: Conventional Transmissions getting clipped
tnbound
Middle TN
I have the SD200 and my Conventional transmissions are getting clipped as soon as the scanner stops on a signal and someone starts transmitting. I am running DND Priority with 2 second interval. I have tried it every way and cannot get it to stop happening. I had this problem a long time ago and forget what solved it. I have read Marks easier to read manual and nothing seems to work. I was hoping someone may have had this happen before and can point me in the right direction? I forgot to add I am using the Sentinel software.
dmfalk
Eureka
Check your delays, then. If they're in the minus number of seconds, they'll cut off.
tnbound
Middle TN
Check resume delay (?) in the upper right hand corner. Should be a drop down menu.
That's was it. Your the man! I used that today actually. Wow I was pulling out what little hair I have left. Thank you guys for all the input.
ProScan
Software Provider
Ontario, Calif.
Same issue two years ago.
tnbound
Middle TN
Yes that was probably the last time I had an issue with that Bob. I enter quick frequencies in there from time to time but never messed with the resume Scan/Search speed before until today. Just another senior moment and Kevin saved my bacon. Thanks again everyone you guys rock.
