Convert Motorola TG IDs
highmaster2
Cropwell, Alabama
I know that elsewhere in these forums there is a link to a page that will convert 6 digit Motorola IDs for use in Uniden, GRE and others. Have tried emailing the owner of that page, but email gets rejected. Question is: does anyone have the actual math formula to accomplish that? Have about 250 IDs in a spreadsheet that I need to convert. The formula would allow me to have Excel do it automatically. Other postings here advise that a simple hex to decimal conversion will not do the trick. Any ideas or sources would be appreciated.
rescue161
KE4FHH
Hubert, NC
You have to enable the hex to dec converter in Excel, but once you do, this formula will work.
"=DEC2HEX(A1-800000)"
highmaster2
Cropwell, Alabama
Scott,
Need some clarification on your formula. Excel help states that the format for this function is DEC2HEX(number,places) where number is the dec number to be converted and places is the number of characters to use. If I use the formula as you have it above (using A1 as the number to be converted), the Motorola TG ID 800987 converts to B005B. What I'm actually looking for is some way to convert the Motorola Type II TG ID to a 5 digit or less ID such as 15792 which is what the same number (800987) converts to using the converter on http://www.mjw.com/scanner/convert.htm. I know that is a correct conversion based on info I already have confirmed in the scanner. Anyway, am open to any suggestions or explanations, especially if I'm missing something.
Thanks!
Johnny
KG4MDL
KE5MC
Lewisville, TX
I am a little rusty on Excel format, but A1 might be the location (A=column / 1=row) of the number to converts.
rescue161
KE4FHH
Hubert, NC
If you put the 800987 in cell "A1", then type "=DEC2HEX(A1-800000)" in cell "B1", it will give you the Motorola 3 digit hex value, which would be "3DB". If you type "=(A1-800000)*16" in cell "B1", then it will show the Uniden value, which would be "15792".
The reason it is dec2hex is that 800987 is a decimal number. You'd be converting the value of (800987 minus 800000), which would be 987. 987 dec is 3DB in hex. That is for Motorola conversions.
Uniden does not convert to hex, so you'd subtract 800000 from 800987 just as before and then you'd multiply the result (987) by 16, which would equal 15792.
Hope that helps.
rescue161
KE4FHH
Hubert, NC
Here is a sheet I just made. It has Motorola converted into dec, hex and Uniden. You could change the formulas around and make a tab for each type of conversion at the bottom, i.e., Motorola to hex, Uniden to hex, etc just like the web page does.
  • TG Convert.zip
highmaster2
Cropwell, Alabama
Scott,
It makes perfect sense after your explanation. I set it up manually just for my own education and the sheet you provided also works like a charm. I sincerely appreciate all your help.
Johnny
KG4MDL
How do I open an .efw file?
rescue161
KE4FHH
Hubert, NC
No problem. Glad it worked out for you. I know I had a hard time figuring out the formulas when I first started out and nobody wanted to give them out. Enjoy!
highmaster2 said:
Scott,
Johnny
KG4MDL
WayneH
Forums Veteran
Your master site
I'm not sure what this has to do with this thread but I don't appreciate you attempting to hijack the thread.
If you would have searched with Google you would have found out it's a file that was originally a ZIP file but was renamed by virus scanning software.
