Cookeville, TN
Mbrowning
Cookeville
So I'm seeing the agency on my BCD325P2 screen, but no audio. I'm using Pro scan. What might I be doing wrong? It's Cookeville in Putnam County TN.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
So are you listening to their talkgroup on TACN (50751) or the patched DMR conventional channel? If the latter, does your scanner have the paid DMR upgrade?
Mbrowning
Cookeville
I did get DMR upgrade. I have a TYT portable radio and can't hear Cookeville Police on DMR anymore, so they've obviously switched to something else.
Whiskey3JMC
Philly burbs 🇺🇸
I searched the Tennessee forum & found this post reporting Cookeville PD has gone fully encrypted. If you or @motohead10 have confirmed this then a DB update should be submitted to get TGID 50751's mode changed to "TE" to indicate full encryption & to prevent future confusion. Assuming the conventional DMR patch is no longer in use that should be marked for deprecation as well
Mbrowning
Cookeville
So Putnam Sheriff will encrypt depending on the nature of the call, but I still hear a gurgling sound (encryption sound) on my TYT radio (DMR). Even if Cookeville police is encrypted, wouldn't it transmit that same sound?
