Cookeville, TN
Mbrowning
Cookeville
So I'm seeing the agency on my BCD325P2 screen, but no audio. I'm using Pro scan. What might I be doing wrong? It's Cookeville in Putnam County TN.
Whiskey3JMC
Don't feed the squirrels
Simulcastylvania, TE
So are you listening to their talkgroup on TACN (50751) or the patched DMR conventional channel? If the latter, does your scanner have the paid DMR upgrade?
Mbrowning
Cookeville
I did get DMR upgrade. I have a TYT portable radio and can't hear Cookeville Police on DMR anymore, so they've obviously switched to something else.
Whiskey3JMC
I searched the Tennessee forum & found this post reporting Cookeville PD has gone fully encrypted. If you or @motohead10 have confirmed this then a DB update should be submitted to get TGID 50751's mode changed to "TE" to indicate full encryption & to prevent future confusion. Assuming the conventional DMR patch is no longer in use that should be marked for deprecation as well
THEMAGICMAN
Cookeville is not currently Encrypted the live broadcastify feed still online as well
Mbrowning
Cookeville
So Putnam Sheriff will encrypt depending on the nature of the call, but I still hear a gurgling sound (encryption sound) on my TYT radio (DMR). Even if Cookeville police is encrypted, wouldn't it transmit that same sound?
NJohnson42
Nope they are still on dmr. Mine still gets them
Mbrowning
Cookeville
Do you have it set to a slot 1 or 2 or any
Slot 1. I have everything set as the database states. I was hearing them until about 4-5 months ago, then the channel just went quiet.
And as for the broadcastify feed, I listened to it a few weeks ago and it is actually Putnam Sheriff talking instead of CPD.
