CP200d Firmware Issue - Analog to Digital Upgrade
djahner99
So - I have several CP200d and a few CM200D radios with firmware that won't directly upgrade to the M2020 suite of firmwares. Specifically R01.01.21 and R01.01.30 for both the CM and CP radios. I've already used the Analog to Digital entitlements on these radios and would like to have firmware to get them digital capable, and since MOL has been dissolved I'm not sure where to turn. Any workarounds or options at this point? TIA.
hockeyref2
Northern MI
Once you add the entitlement, you need to re-flash the firmware for digital to work. It can be the same as the existing firmware. I think R01.01.49 is the highest you can go without paying for SUM. That is equivalent to r2.10.10, before they went to M202x firmware names. The new site is customerhub.motorolasolutions.com R01.01.30 is equivalent to R2.09.
djahner99
The problem is I do not have the original firmware and Motorola has since discontinued MOL with any firmware older than the M2020 suite, which R01.01.21 and R01.01.30 will not upgrade to. As far as I can find right now, there isn't anywhere I can get the firmware through Motorola, at least on MyView.
hockeyref2
Northern MI
2.10.10 (1.1.49) is available under "Mototrbo NA Commercial Devices" The new website is customerhub.motorolasolutions.com my old MOL login is the same as customerhub / myview was.
