CP200d Programming cable/driver
zacsharpe
Hamlet, NC
I'm attempting to program a CP200d and im having trouble finding the driver and getting the radio to read. I get error number 1687 "unable to detect applicable device"
clbsquared
Isle of Wight County
It takes a mini or micro USB. I think it's a mini, though. Some cables have a thicker shoulder on the rubber coating. You may need to trim it back and make sure it's seated good. When the cable is seated correctly your computer should acknowledge it.
Sent from my HTC One A9 using Tapatalk
clbsquared
OK. Sometimes it doesn't play well with windows 10. It does take a while for the driver to load. Once the USB is plugged in and the radio is turned on, it could take a while. Also, you might check to see if you're. using a USB 3.0 or 2.0. If it's a 3.0 it can be a little quirky. 2.0 works the best. Look in your network connections as well. It should show up with an IP address.
zacsharpe
Hamlet, NC
Will do, as far as the driver, it should upload by itself? I get the little yellow caution sign when i look at it in device manager.
clbsquared
I would try uninstalling the RNDIS driver and start over. You may have tried to read the radio before it was fully loaded.
clbsquared
Try turning the radio on before you connect the cable to it and give it some time to load. If that doesn't work, I'm afraid I can't be of much more help. It could be something above my pay grade....LOL.
avdrummerboy
Mohave County, AZ
Hate bumping an old thread, but have an OEM Motorola cable that was not cheap and am also having the same issue. Did you ever have any luck getting it programmed or was it a no go. I tried contacting motorola as well as some third party vendors to see if there is some driver to download somewhere and they are all always very confused by the question.
Project25_MASTR
Millennial Graying OBT Guy
Texas
When in doubt...reinstall the CPS.
clbsquared
I know on the mobile (CM200d) when you connect the radio to the computer and it installs the driver, it will ask you to choose which type of network to assign to it. Whether it be a home, work or public network. You have to choose one. Otherwise it will not establish the connection. I'm not sure in the portables though. I would assume it's the same.
