Cps 16 error #1837
CHangen702
Henderson, NV
Last night I was working on a code plug after updating my tough book and now I get error #1837 file not found or corrupted. I uninstalled cps and reinstalled it but the error is still there. I can read/write and make changes in cps but can not save any of the work on my code plugs. Any advice would be helpful.
Ohbe1
Waterford, MI.
Run CPS as Administrator. That has fixed that error every time I have seen it.
I had the same issue after having to install software again after a partial recovery on Windows 10 laptop. I never had to do that before. I just opened it and never saw any errors. It worked for me too. Any explanations as to why?
Thank you. :)
Ohbe1
Waterford, MI.
I think you are right! I believe it is a Windows oddity. I use Fldigi software and had problem getting Rig-Cat to work with my IC-7300. I had documented the settings from Rig-Cat and Hardware only to find those settings no longer worked. About 35 minutes of changing the variables in both of those settings, it finally worked. I then documented that and now they are the new settings. I believe it was the result of the fresh recovery install of Windows 10 that set up a different environment in the OS.
The error recommended reinstalling the CPS , not uninstalling it. I would never uninstall it because I would have lost my only Wide Band Entitlement ID that I purchased the other day from Motorola Solutions in Georgia.
I though I would do a search for the problem and it led me here and that save me the time of the reinstall.
Again, thank you for the quick work around.
