CPS 2.0 Problem
mcgee508
Pensacola, FL
I have a sl7550 i am trying to get CPS 2.0 to Read / Write and I continue to get error #101005
CPS 2.0 V2.110
Radio is
sl7550
Ver : r02.06.03
Any help would be greatly appreciated
KG4INW
Midlothian, VA
That level of firmware may be too old for CPS 2.0. Try reading the radio with older CPS (original 16.0 build 828 or older) and see how it does. If that works, you'll probably want to not use CPS 2.0 since it's not as nice to use as the original software. A firmware bump may be required before attempting again with the newest CPS.
mcgee508
Pensacola, FL
I’ve tried 16.0 828 and it won’t read it either. I’m banging my head against the wall with this thing. I’m not sure about a firmware bump
tweiss3
Is it time for Coffee?
Ohio
Try reinstalling the motorola drivers from MOL.
mcgee508
Pensacola, FL
OK SO I GOT THE SOFTWARE FROM MOL AND ITS WORKING CORRECTLY NOW. NEW ISSUE IS ERROR CODE #1236 Please Enter Valid RAS Key Value. When i change it to none in the Security Tab it still pops up during the Write command.
Thanks Everyone
n3obl
ØAES-1056
PA
click delete for the ras key. you want to remove it.
