CPU processor requirements.
Brianliff
Atkinson, NC
I bought a Clearance computer from Best Buy in hopes to use it for a broadcastify channel. What are the minimum processors that will work? Not sue if my new cable will get here before my 2 week return window. This thing has a intell Celron J4025 CPU @ 2.00 GHZ. Will something like this work? not planning on doing much other than broadcasting the live audio feed.
n0esc
Signals, Secrets, Static
SE MN EN33
It's more likely that an entry level all-in-one PC like that will have more problems running Windows than it will with any of the software to run a Broadcastify feed.
Here is a thread on Reddit about this type of PC, maybe even the exact model number depending on how long it's been on clearance. Plenty of ways you could possibly upgrade it, or if you are willing/able to install some type of Linux based OS in place of Windows, that will stress the system a lot less. Either way, uninstalling and/or disabling absolutely anything and everything extra installed by the manufacturer, and any extra bits of Windows that aren't absolutely necessary is also highly recommended.
