Hi guys well i finally got my scanner took forever on ebay must be a good one every one wanted them
I ended up getting a BC796D it comes with power but no antenna , So heres the problem and the question ,
I live in a tight valley with tall hills on 3 sides of the house , so i need a antenna that will get out of the valley , up in back of the place it has a old farm , foundation only really but there is power lines running up there , power is not on fuse is taken out off the lines at the pole at the house , Runs about 1/4 of a mile up the valley ,
so is there a way to use that pair of power lines as part of a antenna system ?
Or use them to run up to the tel-pole up at the old barn and hang a antenna up there ?
or what would you suggest ? ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
OK HMMM i think i found the answer and its ,,,,NO it will not work to much loss of signal in that type of wire
how about running over head cable between the poles like the phone lines run its a 4 pole run to the top ?
I included a pic so you can see what I'm talking about
