Folks,
I'd like some feedback on how I could improve my HF SWL Antenna setup. I've setup a ton of long wire antennas in my past, but this one has given me far and above the best performance that I've ever gotten from a long wire antenna. For the most part, noise is low, reception is great. However, I want to make it even better.
Some complaints and concerns that I have about this setup include:
1. Mid-Afternoon noise levels, especially around 15MHz are pretty high. Around S5+ - lots of spatter, grinding, etc.
2. Neighborhood noise can come and go - but I'd like to reduce it as much as possible. My plasma and garbage disposal especially can really blast noise into the 15MHz band.
So, here is the setup, and I welcome opportunities for improvement.
First, the antenna is primarily used for UTE SWL listening, and the primary receivers that use it include an AOR AR5000 and an Icom 8500.
The antenna is a triangle loop based off the Par Electronics End-Fedz SWL antenna kit. I added approx 60 Ft of additional wire on the end of the supplied black wire and fed it back to the end-fed Balun. In the picture you can see I attached the end of the wire antenna to the right most terminal (I hope that is the right way to do it). The Balun then has 100FT of RG-6 75 Ohm cable buried back to the house, which connects to a grounding block at the point of entry into the house. The lead in from the grounding block is another 50ft of RG-6 75 Ohm cable that connects to a multi-coupler for distribution to the radios.
The outside grounding block is NOT grounded to a true earth ground, rather it has about 1 foot of aluminum wire that has been "pushed" into the ground. The ground block is one of those F to F connector ground blocks that comes with a Sat TV installation kit. I actually own a full length copper ground rod, however I live on land that is literally solid rock about 10 inches under the soil and there is no way for me to drive it into the ground.
Here are the pictures of the setup. I welcome constructive feedback and opportunities for me to make this antenna even better. The first picture is a diagram of the setup, the run, and the fence house positioning etc.
