Base Antenna Basics...
SE Texas
I know that antennas can be designed to TRANSMIT directionally, but can an antenna be designed to RECEIVE directionally?
I appreciate all the input and ideas that have been shared here.
I've read several posts, in this thread and elsewhere, that allude to an antenna's effectiveness because it gets out well (i.e. this is my antenna and I can talk all over).
That's not the real target here.
There's a Toyota Tacoma parked out in the woods running a 60 watt PEP through a 7' Skipshooter...
That's the only signal I care to capture and I want to hear it at the theoretical limits.
Should I be considering a horizontal antenna?
Yes an antenna designed to transmit directionally will also receive better in that direction. Horizontal would not work for your signal of interest. He is transmitting vertically. You would need vertically polarized beam antenna. Such as a Yagi, etc
prcguy
Antennas are reciprocal on transmit and receive, whatever direction they do on transmit will be the same on receive. If the Tacoma scenario is local or somewhat line of sight you want to have the same antenna polarity which would be vertical in this case. If the Tacoma was 1200mi away then its a tossup if vertical or horizonal would be better, with some height discussions to go with that.
SE Texas
Plenty of opinion on vertical.
Start somewhere with reviews.
Wind Load (storm damage) gets my attention.
My Sirio 2016 has been through some crazy winds. Direct hit from hurricane beryl. A hail storm that had to be the craziest weather I have ever seen. If it got damaged I can’t see it from the ground. My car 🚗 is another story.
jcrmadden
So I'm assuming that even though the individual elements of a Yagi are horizontal, their configuration results in vertical polarization?
I looked at several yagi antennas and their modeled radiation patterns. The main lobe is always in one direction, but relatively broad, flat, and horizontal.
I'm also assuming that most of those models are created with theoretically perfect conditions in mind (free space?).
prcguy
If you mount a Yagi with its elements oriented vertical it will have vertical polarization. Antennas are usually first modeled/analyzed in free space then takeoff angles due to height or mast interaction will be installation specific.
jcrmadden
As a budding antenna enthusiast I can attest that its a lot of information to digest in a single lunch break...
I think I'll take the rest of the day off and build an antenna.
slowmover
Fort Worth
Keep Momma happy whether at home or on those camping trips.
H-D has the correct “antenna taps”.
Well, okay, she might have to tote that laundry basket of wet garments up the hill . . .
. . but as a friend a friend to your family I offer a solution:
Several men of my acquaintance report they also find them useful.
prcguy
Not the right way to approach this. You need to quit your job and dedicate all of your time awake and asleep to learning and building antennas. You can't learn what you need to know with a job getting in the way. Unless you work at an antenna company of course.
SE Texas
2 element mounted vertically think it’s a Maco, and yes the listed specification probably are only achieved under ideal conditions
Even though I’ve built quite a few antennas I have never used a modeling program. It’s my understanding and software like. EZNEC You have a choice or choices like modeling, free space real world and more.
SE Texas
By no mean an expert here but when I first built a dipole and it performed incredibly well the only logical next step was to build a yagi!!! After all they are just a dipole with some parasitic elements. So that is what I did. At any rate I was rather successful. I didn’t use this model in this video but my bet this guy is right. Check it out.
jcrmadden
This makes sense... Guess I need to start an antenna company.
@slowmover there's about to be a telescopic painter's pole and five gal bucket in the back of the yota...
That way I can deploy the collapsible "yota yagi" prototype when stationary...
If it works I'll name it after you lol
niceguy71
Massachusetts
that great QT60 of yours and that great mobile set-up should talk 30 plus miles local on side band???? have you tried to reach anyone??? I think you could put a better antenna on the Wifes vehicle and you two could reach each other if you tried.... if you both got your ham licenses you could use a ham frequency... that would be a much quieter channel / band and you would be able to communicate without even having to buy a Base Station.....
if you like radio like I do.... you'll want the base station anyway.
slowmover
Fort Worth
The Boomerang A as shown in test linked appeared to do well. Very light in weight. My shorter version will fit where I can store it, including in truck (have to build a case for that).
He reports 50-miles SSB to a base at higher elevation and a “big” antenna. Given his low mount next building in condo courtyard I thought that okay. 8-miles to big truck on highway. That’s a Cobra 139 + W-M DSP outboard.
But if I got in a hurry it might not be durable. I’m not recommending anything, I just wanted low cost plus E-Z set-up & take-down. I’ve seen it as adjunct to having TT parked.
The pole itself may have other uses just as with pipe & bucket. Seems decent for price. Good basis with which to start.
slowmover
Fort Worth
If you’re feeling bloated after dinner then head over to QRZ and type in, “Base Station Antenna”, as a general search.
Use, “Lightning” as cross-reference term.
An Alka-Seltzer, too, and the voices, the voices, will soon lead you to La-La Land and a peaceful nights rest.
— It’s real easy to get in the weeds with this thread title subject.
