R30 Cross A/B Band Interference
eorange
♦RF Enabled Member♦
Cleveland, OH
I've been noticing that scanning certain modes on one band causes interference on the other band.
A Band: scanning 200 MHz AM frequencies.
B Band: scanning 400 MHz P25 frequencies.
B Band scanning then causes a birdie on the A band, which persists even if I stop scanning the B Band.
Same thing happens in reverse - scanning 400 or 800 MHz P25 frequencies on the A band causes birdies on the B band scanning 200 MHz AM.
I've narrowed this down to P25 causing the issue. Anyone notice anything similar with other modes, like NXDN?
bearcatrp
Land of 10,000 taxes
Do you think its over modulation from P25 causing it? I get P25 very strong in my location from 4 different simulcast sites not to far from my location. What are you scanning for P25 in the 400 Mhz range?
eorange
♦RF Enabled Member♦
Cleveland, OH
I was trying to scan some recently activated 400 MHz federal frequencies, but they are too far away for me to pick up. And that's the strange thing...the cross-band interference (or whatever) was occurring even though I wasn't actually receiving any 400 MHz P25.
I just tried it again now. 400 MHz P25 B band scanning was causing a birdie on A band 260.200 AM. As soon as I changed the B band to something else (like AM airband) the birdie went away.
vagrant
ker-muhj-uhn
California
Try your same scan again using a dummy load, or no antenna at all, as well as moving to a different location.
vagrant
ker-muhj-uhn
California
@eorange Any update on the results when using a dummy load, or no antenna as well as relocating? Others may benefit from your results.
eorange
♦RF Enabled Member♦
Cleveland, OH
Ok, I'm back. Relocation made no difference with the antenna on. The extent was inside my house vs at the end of my driveway. Next time I'm out and about I'll do a better relocation test.
With no antenna...the interference seemingly caused by 400 MHz P25 scanning (with no stations received) disappeared. This was the case whether P25 A-band and AM B-band or vice versa.
