I have a strange problem. We are a PA state humane law enforcement agency. We have two Uniden scanners (a BCD536HP and a BCD436HP) that we use to monitor local police: one for the city of Chester, PA, and one for all other Delaware County PA police departments. The feeds are then pumped into two TeamSpeak clients running on separate computers via a cable plugged into theheadphone jack on the scanners to the line-in port on the computers. The TeamSpeak clients are monitored by our LEOs in the field.
Based on a recommendation in the RR forum, I purchased a PCT-MA2-4P drop amplifier to split the signal from our discone antenna. Here is the problem: When I go to connect the second coax going from the splitter to the scanner, I can hear crackling and humming in the PC speakers of the first scanner, similar to if you touch the connector of the computer's line-in cable. Once the coax is fully connected, the output from the second scanner can be heard through the speakers of the computer connected to the first scanner. Weird...
Any suggestions on what may be causing this and how to remedy it?
Link to splitter: RF amplifier passive return CATV amp PCTMA24P | PCT Store
