CS-f620tr adj software
WRJZ927
Hello all!
I have 4 Icom ic-f621-2-tr radios and have the cloning software to program them but I need the adj software to adjust the RF power output. I have scoured the internet and cannot find any place that sells it. Usually I can find a package to purchase that has the cloning and ADJ software in the same bundle but not this radio. I thought I would have gotten it as part of the package I purchased but not this time... Any help is appreciated. And yes they do make an ADJ software for this radio, it mentions it in the service manual.
Thanks in advance,
Colin A.
It's been a -really- long time since I tried this, maybe something changed in newer software revisions...
Warning/disclaimer/covering my rear:
This can open up things that have risk. If you do not understand 100% what you are doing, DON'T MESS WITH IT.
Not sure if there is power output adjustment in here, but you can give it a try:
-Open the software
-Click "help" drop down menu,
-Click "about CSF500"
Type in: reserve
Yes, there's no field to type it in, but type in on the keyboard.
That is supposed to open the "maker reserve" functions of the software. That should open up a few options that you wouldn't normally see.
Refer to warning above.
You do need to be super careful messing with power output adjustments. There are some settings that will let you set the Low, Medium Low, Medium High, and High settings. Actually going in and changing the maximum/minimum settings requires many steps and a service monitor and ammeter. Usually the procedure requires adjusting power and watching current consumption.
WRJZ927
These radios use the cs-f620tr software not the cs-f500 software but I did do that and it did open up the reserve options but there is no RF power output options in that, thanks for the info though!!
Yeah, sorry about that, meant to edit it. That procedure applies to a lot of the older Icom software. Same steps for different software.
Oh well, it was worth a try.
You might try and track down a service manual for that radio and see if there are options in there. I think there may be a way to activate what you need from the front panel and adjust using the correct test gear just using button presses.
KD5FMU
Ham Radio Crusader
Henryetta, Oklahoma
Hello all!
Thanks in advance,
Colin A.
Were you able to get a solution to this problem? I have acquired some of these exact radio to make a GMRS repeater and the software is different from the 121's.Also I need help with the cable diagram. Can You help?
