CSERN No longer working
Snowbrder086
Tolland, CT
I’m using a Uniden BCD996P2 here in Vernon. Reception is very good. I had the scanner up and running with Troop C, Troop K, and Coventry. All three on the new state system. A few days ago I noticed that they are no longer coming through on the scanner. Any ideas? I have the updated firmware and I used the radio reference link to download all the frequencies and talk groups so everything is up to date. Thank you!
cg
Connecticut
Check for locked out control channel. Hit hold and be sure you have 774.05625 showing. Scroll through the Troop C Simulcast freqs and be sure it is there and not locked.
chris
Snowbrder086
Tolland, CT
chris
Unfortunately that isn't the issue. I just wiped the scanner and then redownloaded the updated firmware. I then re added all the frequencies to the scanner. It doesn't look like any of the CSERN is coming in.
