Hi again,
"The case I'm talking about uses an OR squelch gate."
You're taking me back to the days of learning the difference between gates, or, nor, and, nand, if, maybe, sometimes, not, and tied in knots. Uh, I guess you can call it dual squelch at ten paces, turn and fire the repeater, choose your squelch weapon. "Give it dynamite and give it DEATH!"
It's too early in the evening for me to get slap happy, what's WRONG with me?
"Now, as for your example of CTCSS licking in a preamp, that makes no sense. IF the signal is below the decoder level, it won't benefit from the preamp at all. Or are you saying it took a strong enough signal to 'kick' the repeater and then the preamp kicked in to make the signal less noisey?"
Sort of, when dual receivers are used one is selected with a voter. It's done with PL/anti-PL so the voter has but one choice with no chance of confusion. Naturally the PL receiver is the one with the preamp so for all practical purposes the presense of a tone activates the preamp. Does it make sense now?
"Its RADIO. Never the same two days in a row (at least around here !!!!) Steve"
Calm down man, give me a moment to gather my senses and let my ears stop ringing.
Ah, that's better. Enhanced propagation aside I have noticed 6M signals with plenty of QSB where there should be none, margial signals will often fade in and out unexplicably. 2M signals tend to be rock solid while 1.25M ones fade up and down. 70cM ones are mostly rock steady but weaker repeaters will fade right out at the time you're in the middle of an important QSO but when you're just chatting it's 5/9. It's Murphy you know, it's MURPHY! He knows better than mess with my new scanner, or is it he only likes to mess with me when I'm transmitting?
"Who listens to radio? Only two hundred and fifty million people, that's all."
An old PAMS spot.
