XPR Two-Tone Pager function on XPR7550e via Quik Call II
Motoflightmedic
ÆSØ
U.S.A.
Hi all,
I'm trying to replicate the settings from my minitor 6 to my XPR7550e for two-tone selective call. However, I'm finding that no matter what I do, I cannot get a quick call to trigger. I want it to alert only if the tones 909.8 & 991.9 are heard (third tone set on audio). Any thoughts would be much appreciated. Frequencies & names have been redacted but are correct and accurate. Looking for someone who knows quick call 2 programming pretty well. Thank you.
Audio WAV Here
Channel Config:
View attachment 179148View attachment 179149
Our base always transmits on the frequency with DPL 261. I've also tried setting the signaling squelch to "AND". I've verified that when it was sent to "OR", it keyed on but from the DPL code alone. When set to "AND", I see the light on the radio indicating that there is a transmission, but it is not unmuting/alerting when the audible tones go out.
Signaling System:
I've played with these settings and I cannot get it to activate still.
Contact:
I've created the contact but still can't get it to work.
Minitor 6 Pager for reference:
When you say it wont "trigger" is your radio staying quiet with no audio coming through the speaker, or is it receiving everything like its a regular channel?
buddrousa
Our OP has other Paging issues also.
Sullivan27
NYS
Does anyone know if it's possible to get the alert sounds that are on the HT/EX series on a XPR series? (Standard-Tones 1-7)
firefive76
Kansas
If none of these suggestions have worked, I'm betting its the length of your B tone. QCII is normally 1x3 seconds. The Minitor typically alerts within a second of hearing the B tone. If I remember correctly, the 7550 doesn't alert until well into the B tone, or even at the end of it.
thedelta
It's an analog system, I've verified that the tones are correct. I even used a second XPR7550e to send a quick call on an alternate frequency and it does alert, unlike when the department pushes out their tones, however. I think it is expecting 1x3 sec and not what the department pushes out which is 1x1 sec.
nhfdcadet
CETsr
New Hartford, Ct
there's your problem
doverjd
Hi all,
Audio WAV Here
Channel Config:
Signaling System:
Contact:
Did you ever get it to work?.... I am having issues on programming a button to trigger the QCII tones. My 7550 has a Digital and Analog channels on it, would that be an issue?
