CSV trunking p25 format
BorisG
I am in a country where there is no information at all from radioreference DB (outside the US)
I wanted to use the Import option on a Unication G5 device to write the CVS on my own and upload to the device
The thing I did not understand what is the correct format maybe someone can help me?
my try:
Code:
RFSS,Site,Name,Freqs
1,1(1),test,864.222
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Boris-
this may help--it's a discussion about the CSV headers format:
Example:
Decimal,Subfleet,Alpha Tag,Mode,Description,Tag,Category
1001,,EBRCS Call 1,D,Calling,Interop,System Wide
BorisG
This is a great example of Talkgroup
But I'm looking for an example of control frequencies
Here is the format for trunking sites from the RR database, and the columns Unication looks at:
RFSS​
Site Dec​
Site Hex​
Site NAC​
Description​
County Name​
Lat​
Lon​
Range​
Frequencies​
Each frequency should be in a separate column.
N6ML
Download the CSV from a US location and use it as a template.
BorisG
Can send at least one sample with details please
RFSS​
Site Dec​
Site Hex​
Site NAC​
Description​
County Name​
Lat​
Lon​
Range​
Frequencies​
I understand you need to purchase a subscription for this
Those are the headings, you should be able to fill in the blanks, as download of the information requires a premium subscription I do not feel comfortable sending the RR information.
BorisG
Believe me if there was information about my country I would be the first to pay
You can also send me old / unused information
I did not understand what lon, land, range
Lat, Lon, and range can be blank, that is the GPS (Lat/Lon) location of the site and range is distance site is rated for.
BorisG
Code:
RFSS,Site Dec,Site Hex,Site NAC,Description,County Name,Lat,Lon,Range,Frequencies
1,53,35,37D,test,not use,,,,868.57500
not working...
SITE NAC = wacn id ?
? = System ID
The WACN ID can be set to 'FFFFF' which means radio can automatically search and match a appropriate WACN ID to use. The System ID can be set to 'FFF'. You do not need to know the system RFSS (leave it as 1) and Site number may be set to FF.
BorisG
The WACN ID can be set to 'FFFFF' which means radio can automatically search and match a appropriate WACN ID to use. The System ID can be set to 'FFF'. You do need to know the system RFSS and Site number.
Frequency 868.57500
RFSS 1
Site Dec 53
Can you please give me a proper line for CVS
Frequency 868.57500
RFSS 1
Site Dec 53
1,053,35,FFF,test,notuse,,,,868.57500
N6ML
It's CSV (comma-separated variables), not CVS.
It appears that PPS 0.3.16 Beta24 will not import trunked system CSV downloaded from RR today - I get "Input string was not in a correct format" on an unmodified downloaded file.
N6ML
So it looks like RR added some flags to the frequencies (like 'c' for "control channel"), and PPS doesn't like that. This format works:
Code:
1,001,1,1F1,"ALCO Southwest Simulcast","Alameda",37.59306523267257,-122.08495782426564,13,769.293750,769.581250,769.868750,770.331250,770.768750,771.043750,771.343750,771.643750,771.943750,772.243750,772.543750,772.843750
You get prompted for the WACN ID and System ID during the import process (after selecting a properly-formatted file).
w2lie
New York DB Admin
Long Island, NY
N6ML
See if this helps: Fixed: Issues with importing Talk Groups from RR CSV Download
(Fix is only for the TG import, not Site. If you have a problem with site, try looking at the headers)
No, I think this looks like a new issue - RR apparently added flags like 'c' for "control channel" to the Frequencies....
Code:
1,001,1,1F1,"ALCO Southwest Simulcast","Alameda",37.59306523267257,-122.08495782426564,13,769.293750,769.581250,769.868750,770.331250,770.768750,771.043750,771.343750,771.643750,771.943750c,772.243750c,772.543750c,772.843750c
Removing the 'c's makes it work again.
