Curiosity Questions
Haley
I don't post much in this forum , but had a couple of questions----just for curiosity sake.
1. Are there many (any) Federal agencies using P25 Phase 2 systems?
2. Are there any Federal agencies still using Analog VHF, or UHF?
I have plenty of scanners that can cover anything I would ever want to monitor. So my questions are not about models. Just curious about systems and frequencies , Thanks Mike
nedhc47
Ocean City, MD
National park service at Assateague Island National Seashore in Berlin, MD still uses vhf p25 phase 1. The USCG in Ocean City MD uses mostly vhf unencrypted here also. CG111
Sent from my iPad using Tapatalk
troymail
Silent Key
Some time ago, I saw some brief testing of Phase 2 on a 380 Mhz system in the MD/DC/VA area -- probably JNCR.
Haley
Thanks for the replies so far guys! Kind of what I was thinking, probably quite a few different types out there. I suppose it has (somewhat) to do with budgets, and agencies? Mike
ecps92
Taxachusetts
Phase II would be for a TRS, I would not be surprised if some of the TRS Systems are Phase II
Yes . there are Analog users, altho they are slowly going to P25 and DMR
The only way to find out in your area is to spend a lot of time searching
138-144, 148-150.8, 162-174, 380-400 and 400-420
Activity may not be as frequent and regular searching will only tell.
An example this week for me was a formerly Simplex only "Analog" seems to now be a Repeater - for the local Army MARS
As an added not to the original question, some you may only find by on-scene and durign certain hours/events. Example is the Morning/Evening Gun Salute from a Naval Vessel here in Boston is still very VHF and very Analog
Haley
I actually do search those ranges quite a bit. My location is just not a high traffic Federal area. IF I do hear any activity , it's usually U.S. Marshals, I.C.E., and /or D.E.A. But they are always on my local trunked system (which is P2 ----with lots of P1 radio's). They have assigned TG's., but they are not regular's on the system.
I actually did hear in Florida last year (what I thought) was T.S.A. on DMR. Unless it was a private security contractor. Mike
ecps92
Taxachusetts
What Area ? as your profile is blank
Remember, traffic comes and goes.
Budgets, Vacations, etc
TSA is P25, altho the USPS and VA do use DMR
what Frequency ?
Haley
what Frequency ?
I live in the middle of Iowa. When I do hear the above mentioned (ATF a couple of time also), they are usually in with the Polk County Sheriff"s Dept. TG's. It is pretty rare though. On the other hand I am in the land of RACOM , I hear tons of TG's that are not local.
Last year my wife and I flew into Ft. Meyer's Florida. I assumed what I heard on DMR were TSA (because the airport did have agent's) , but like I said maybe contractors?? They were security of some sort for sure. Mike
ecps92
Taxachusetts
Near Des Moines ?? Can you be more specific, the state is big :D
Had a friend who lived in that area for awhile, he found plenty just searching
ICE has a pretty extensive network - all depends on where you are.
Haley
About 40 miles NNE of Des Moines. Actually have 3 decent size systems I monitor. RACOM mostly EDACS ,Provoice although not much anymore ,most of LE have moved to the P25 systems (700/800mhz). Also the Iowa Statewide System (ISICS), P1 and P2 radios in use, and the Central Iowa Regional Public Safety Communications System (CIRPSCS) also P1 and P2 radios in use. Various surrounding counties use anything from analog VHF/UHF to single P25 VHF and P25 VHF systems. Partial encryption is used on some of them. A diverse area for listening as far as types go . And of course the multi-state power company is DMR tier 3 , as are the state prisons. And of course the curse word phrase is used often also, "call me on my c-phone"
ICE and U.S.Marshals are in my area quite a bit , our new jail is a pickup center for holds. Mike
ecps92
Taxachusetts
Thanks, much easier to provide a better formulated Response, knowing a location
Since the Topic was Federal, I will keep it there, others local might have more Non Federal input
Federal Courts - you will find the Court Security Officers [CSO] generally in the 170.7000 - 170.8500 Range
You should be able to hear ICE in your area, they maintain a Wide-Area [Possibly it is Vote Scan] Network [approx 12+ Repeaters] Your nearest is might be Waterloo
they all should be using a NAC of $791
Being near Des Moines, how about FPS in the 400 Band and when Winter leaves [might be winter traffic] see what the ACoE [Army Corp of Engineers] is using in VHF
All notes for Des Moines Area
Add to this Civil Air Patrol in VHF [148.125 or 148.150]
BATFE - VHF
Air National Guard - VHF
TSA - VHF [if near the Airport]
USPS Inspectors - UHF [generally ENC]
USPS Sorting Facilities - UHF
and then also the VA Hospital VHF and UHF
Haley
BATFE - VHF
Thanks for all the new search "ideas", really appreciated! I am actually getting tired of the local PD , been "expanding my horizons". Whenever I travel,I search for Federal, RR, and believe it or not NOAA as my prime targets. Locally, I always have the 162-174, and 400-420 ( and recently, 380-400) ranges programmed-----I am guilty of not searching them long enough (or having enough patience) , Thanks again, Mike
ecps92
Taxachusetts
Welcome to the Federal BUG
:D
