Custom Programming sds 100 sds200
natedawg1604
Colorado
The thing is, there's a lot of stuff that isn't easily categorized as belonging to a specific county. For example in the RR database each state has a huge section for "Federal", within that you will find (just 1 example) different sections for the various forests within the state. They are not broken out by county, they are broken out by each Forest.
Same with railroads, the big railroads are broken out by subdivisions. There are many examples of this.
Honestly the bottom line is this: if your relying on someone else to program your radio, it will never completely meet the needs specific to your location and (most importantly) your own listening preferences.
mhammerf150
i dont know. i just think i would like a favorites list of each site i shared a link to. i think that would get me going somewhat
hiegtx
Dallas, TX
<snip>
You're dead on target.
Plus, whether you (the OP) pays someone for programming, or someone with spare time does it free gratis, what are you going to do when something changes? County, city, and state agencies have changes quite often. Businesses come and go, get bought, change systems or locations. While everything does not change 'overnight', changes can and do occur regularly. Some may not affect what you want to hear, but others will. Are you going to continue to pay someone to re-do the programming on a regular basis? If someone created a couple of Favorites for you, at no charge, they're not likely to want to continue doing updates at no charge on a regular basis.
Hi can someone please help me that knows how to use the software good for the sds100 and put these 2 sites in 2 different favorites lists for me please? More Fast Food Frequencies and Allegheny County Scanning Page - PGHscanner.com . I would be willing to pay if someone can make me 2 favorites lists out of these. Thank you
The 'fast food' link you provided is for the Long Island area, and is dated for May of 1996. A few of those frequencies might still be used in your area, but not necessarily by the same company. Also, almost without exception, all of those are used simplex, not through a repeater. Reception would be limited to probably a few blocks from the restaurant, almost certainly not much over a mile.
For the Allegheny page, just spot checking a handful of the frequencies, they don't match what is in the current database page for Allegheny County. On the page you linked, frequencies 453.1375 and 453.2375 are not listed. They are on a license for Allegheny County, issued in 2020, and updated (in the RR database in the past few days, to indicate that encryption is being used.
A number of the frequencies on the page for various businesses are also simplex, not repeaters. As with the fast food frequencies, simplex transmissions have a very limited range. Also, some are DMR, some NXDN. Do you have those upgrades?
For Allegheny County as a whole, you can easily create a Favorites list of all the conventional channels by going into the main database in Sentinel, opening the US set, then drill down to Pennsylvania, and then Allegheny County. Highlight the ones you want, and <right><click> to append them to an existing, or new, Favorites list.
The trunked systems on the RadioReference database page for your county are not correctly identified on your Allegheny County page link. U.S. Steel, for example, is listed in RR as an LTR trunked system, but the frequencies are on your referenced page as if they are conventional. That's not going to work correctly. Triconnex is another system that is on your list, with frequencies listed, but to function correctly, those must be entered into a trunked system, not programmed conventionally.
Finally, with the mass of frequencies you are asking to be programmed, even if re-figured & done correctly, you're going to miss more than you hear, as it will take quite some time for your scanner to wade through all of the data, then start scanning a second time.
mhammerf150
but if i had all in a favorites list from Allegheny County Scanning Page - PGHscanner.com couldnt i just turn everything off instead of business's and just listen to business if i wanted to? and for instance the next day if i wanted to just listen to police then just turn off everything except police. I wouldnt listen to the whole list at the same time. just parts of it. Yes i have all 3 upgrades. I think i have 3 links to fast food freq's.. i dont mind them being low power because i will have my scanner in my truck with me and i live very close to like 4 of them also. thanks for the help
hiegtx
Dallas, TX
I see a lot of errors & omissions in the list on the page you referenced. That especially applies to the trunked systems that either are ignored, or are presented (on the page) as if they are a collection of conventional frequencies. As for the business frequencies, I have doubts about how accurate the listings are. Just randomly spot checking, some are no longer valid, or the company (or facility, such as a hotel) has changed names or ownership
You could control what part of your lists you monitor if you use quick keys, with one set (say, for example, 0 to 15 for law enforcement, 16 to 30 for fire, 31 to 40 for EMS & Hospitals, and so on). Using quick keys to control what you hear is much easier than trying to do it by turning service types on and off.
If you appended what I had in the screenshot in post 24, that would create a Favorites list with the conventional frequencies in the RadioReference database, such as public safety & various other types, and also including various businesses. While it's your choice, your scanner, I also think you are overrating how interesting the fast food frequencies would be. But if you really want them, then look for a more up to date list.
mhammerf150
so how would i go about getting someone to help me with the errors and fix things for me? This is what im asking for. I'm asking for help and willing to pay for it. I am clueless about the software and just dont have time to learn it right now. Working 10 to 12 hour days. The sds100 will be an old radio before im able to find the time to learn the software lol. that's why i want to pay someone to help me make a couple of custom favorites for me. It dont need done over night or anything.
hiegtx you seem like you really know what is going on here. I'm hoping that you are willing to take a crack at it
