Custom Tone Settings
policefreak
Berlin, NJ
So I'm a bit disappointed. I figured I might try and get creative. I downloaded some MP3 files of some Minitor alerts and I even used Audacity to create my own and saved them as WAV files. They sounded good and I was exciting. When I uploaded them in the PPS under the custom tone setting and played them back they sound hideously overmodulated and distorted. I threw the files back into audacity and lowered the amplitude. Still sounds terrible. It even freezes up my G5 pager when it goes off. Did I miss something?
waynedc
Vail, Arizona
Try "8 khz 8 bit Mono". That is what I use with my G5 Zone Voice Files.
I had the same issue when I tried "16 khz 16 bit Stereo"...
Wayne
waynedc
Vail, Arizona
It is not a setting in the PPS. When you create your alert files, record them as "8 khz 8 bit Mono" sound files. I created .wav files for each of my voice files that announce my channels in each of my zones.
For your situation, I think you need to go back to Audacity and reconvert your .mp3 files to .wav files but change them to "8 khz 8 bit Mono" then save them.
Wayne
krokus
Southeastern Michigan
When I made the profiles for our G4s, I had to drop the level of the minitor beeps by a lot. (IIRC, about 24dB. I would have to look at the files.) Otherwise the alerts were annoyingly loud, or the volume set so low that the radio audio could not be heard.
