Data Base for GMRS
Hi, Would it be possible to add a data base for GMRS by zip code to the RR data base ?
Thanks Brian
There are a lot of GMRS databases out there already. A quick Google search found these;
FCC has one here..
myGMRS.com has one here..
And Repeaterbook.com has one here...
Natrona Heights, Pennsylvania
FCC has one here..
yep. i have used all of them. Just want to put in zip code in (You know what the hams have).
If you are using zip code to find ham repeaters in the RR database, you are missing a TON of repeaters. RR is not a good source.
That's why he wants RR database to add a section so they can be tracked in the RR database, he wants RR to do the work so he doesn't have to.
Not really, GMRS is getting bigger I just thought it could be done without pulling teeth and smart comments. That why!!! I thought when I asked it would be a issue and I was right. Dont really care for RR anymore.
You must be sucking up to be a ADMIN or somethig. God forbid someone comes up with a idea .
vagrant
ker-muhj-uhn
California
Play the odds…
- GMRS repeaters are either Open or Closed.
- Many ”open” repeaters often use a PL Tone of 141.3.
- There are only eight frequency pairs for GMRS repeaters.
- Program eight using the 141.3 tone.
- Enjoy using an open repeater and often avoid unauthorized use of a closed repeater.
Is there really a need for RR to have a database of closed repeaters, including open ones that may not even be working any longer?
Play the odds…
IM looking for people to to get into GMRS NOT NOT NOT repeaters. The ham data base you can use the cll sign.or zip code or the hams name. I thought I could ask for the same thing for the GMRS people with out getting my face eaten off. I have all what Raleighguy suggested as book marks.
But the FCC database allows you to search by zip code or license holder name, exactly what you are asking for, why wouldn't that work for you?
Thanks , I have it book marked as a favorite . Alll the stuff you mentioned is book marked. Maybe a Data base Admin will answer me or the owner.
The FCC site you posted allows you to search for ham operators as well , however they have 3 ways to find them on RR( zip code,call sign & name) . No harm in asking is what I was trying for .
522
Murray, Utah
Okay, hold on pilgrim. Let me get this straight. You DONT want to get in contact with people on GMRS Repeaters....But you DO want to put up your own repeater?
K9KLC
Southwest, IL
Not really, GMRS is getting bigger I just thought it could be done without pulling teeth and smart comments. That why!!! I thought when I asked it would be an issue and I was right. Dont really care for RR anymore.
Why don't you put in the work and get the database started. Seems you're wanting something and not willing to contribute.
W8UU
Pilot of the Airwaves
Wellston OH
myGMRS.com is probably the best source of GMRS repeater information, including those that are open or private, temporarily off the air, or completely inactive. The FCC GMRS database is the best source for figuring out who is licensed in your area for direct or repeater communication. You'd be hard pressed to beat those already well established resources by trying to take on building a new database from scratch. Both of those resources helped me a lot. Good luck to you on your GMRS venture.
Any database out there that lists all the existing GMRS licenses is going to pull data from the FCC ULS database. That is the -only- authoritative source of license data in the USA.
Based on complaints I've seen on this site about the existing RadioReference.com amateur license database, there's always a delay between the FCC database and whenever they update the RR.com database. That has upset people because it's not 'immediately' updated whenever they get their new license, change address, or something else.
So, if you want up to date and don't want any nonsense, the way to do this is pull the data directly from the ULS page and compile it yourself. That way you get the most up to date info, in the format you want, and sorted the way you want.
Just be aware that the FCC ULS system is slow, crashes often, and is sometimes just not available. If you want to complain about that, you'll have to wait in line behind the rest of us.
