BCD436HP/BCD536HP: Database and firmware don't upgrade.
ve2cjw
Candiac, QC, Canada
Finally got Sentinel to work. It communicates with the scanner and rebuilds the database. I am a Premium subscriber. If I want to update the database or the firmware, my computer freezes and I have to reboot. I tried that normally and also while being logged in Radioreference but it doesn't work. Am I missing something? What could be wrong? I have the latest version of Sentinel.
pb_lonny
VK7AAL
Tasmania
That sounds like a software issue on your PC. Can you reinstall it and also check your Windows Event Viewer for anything at that time?
rgchristy
Delco, PA
I don't know your operating system, but you could try running Sentinel as an Administrator or in compatibility mode.
Whiskey3JMC
LMR Explorer
Philly burbs 🇺🇸
dave3825
Suffolk County NY
Premium subscriber here.
Being a premium subscriber has some nice perks but Sentinel will connect and download the database even for non subscribers so you do not need to be logged into Radio Reference to use Sentinel.
If your using the correct version of Sentinel, I would look in the event viewer for errors.
Select Start on the Windows menu, type Event Viewer, and press Enter to open the Event Viewer.
Click on Windows logs, then applications. Then start looking for errors at the time of the PC freezing.
ve2cjw
Candiac, QC, Canada
The problem happens when Sentinel tries to connect to Radioreference. I get a screen that says connecting but it then freezes . CTRL-ALT-DEL doesn't work so I have to reboot. How is Sentinel supposed to know who I am when trying to connect?
dave3825
Suffolk County NY
Have you looked in the event viewer as suggested to see what info may be listed for the error?
As mentioned, Sentinel does not connect to Radio Reference. Third party software like Proscan, Butel etc, those connect directly to Radio Reference and a subscription is needed.
RandyKuff
Lorain, Ohio
As @buddrousa mentioned above... Who is your ISP (Internet Service Provider)...
Some ISP's block the FTP protocal that the Uniden servers use to update Sentinel's database and scanner firmware...
