Day Wireless Tier 3
theaton
Member N7VU
Moab, Utah
While in Provo over the weekend I picked up a Tier 3 Capacity Max system on 452.325 (H0-121, Color Code 0, neighbor Site 122). It's licensed to Day Wireless (WPNS909) and may be part of a multi-state system. I didn't log any traffic over the weekend, and now I'm out of the area. Can anyone log this with DSD+ or other software and log some LCNs and voice frequencies?
gldavis
KE7MQF
Bountiful, UT
It (452.3250) is weak at my location. I have SDRTunk set for DMR on that freq. I'll see what it can hear. (so far I am seeing TS1 & TS2 as idle.
N7OLQ
Scanning since '77
Utah
I fired up DSD+ again (it has been off since March) and that site comes in pretty strong. Very quiet. DSD has seen 105 radio records, and 21 P25 talker aliases (not sure what those are). In the past hour, just a few conversations. TG-11998024 is the only one active so far. I see only 2 voice channels referenced Ch-1804 and 376. Is there a way to get DSD to display the voice frequencies?
enosjones
Price, Utah
There are windows in dsdplus for the channels/ frequencies show up in a separate window. there are also see group and seen radio windows as well. I just wished there was a seperate window for neighbors or peers to show up instead of just the event window. When I Started using dsdplus I used fmp24 cc and fmp 24 vc to run dsdplus , but now I use the 1R which seems to combine both cc and vc into 1 window, set up for the codes in the notepad txt is the same when u edit the batch file. There is a channels /frequencies window but I can't remember what u use to open it seperate. I have mine set to open so I've just left it.
to answer about the talker aliases theyve added that , its a talker server alias for saving the p25 radio ID aliases like on the new UCA p25 system for unit IDs. Its saved on the server and updated from time to time.
N7OLQ
Scanning since '77
Utah
Thanks. I'll keep playing with it. I'm familiar with P25 aliases on a P25 system, but it was a surprise to see this field show up for a DMR system. Maybe they chose a bad name if they are going to use it for all system types. I may have to connect my second AirSpy for separate voice following to get the frequency window.
