Dayton 2004 Air Show this weekend
jpryor
Nashville / Green Hill TN
http://www.daytonairshow.com/
See in attached zip file. This contains
my Pro 96 file and a CSV dump of the channels. If you do not have Win96, you can at least look at the CSV file to see what all I have programmed in.
Breakdown of the banks I have setup:
0 Important
1 Aviation
2 Air Show
3 Dayton
4 Montomery Co
5 Miami Co + Airlines/Media
6 Common
7 Travel
8 Ohio MARCS + ISR
9 Military
Summary of bank contents, etc:
0: Important coventional frequencies for the airport and immediate
area. Primarily airport opertions and local/area fire and mutual
aid. Also including some federal frequencies: CAP, DHS, TSA, FAA. I
also located a since expired license for "United States Air and Trade
Show" callsign KB31054 for at the airport. I'm including those
frequencies as well, maybe they still have the radios floating around.
1: Civil and militry aviation frequencies related to airports (KDAY,
KFFO, FSGH) and ARTCC. With more of a focus on the military ARTCC
frequencies in the area. I suspect I will lock out less interesting
civil communications as the day progresses.
2: A generic air show bank I'll use a scatch pad for any new
frequecies I may collect. Comes pre-seeded with the common and/or
most likely air show related frequecies.
3: Dayton 800 system, talkgroups pretty much set, will just lock out
any unrelated transmissions.
4: Montomery Co 800 system and related public safety frequencies.
Still working on hashing out talkgroups, not sure if I need any for
SO. I'll include Vandalia and Butler Twp in my final revision for
sure. May also include Harrison Twp. Any other suggestions?
5: Miami Co 800 system, heck they're just north of the airport, maybe
they'll be helping out. Will probably tweak/add to the talkgroups a
bit. But also I have airline frequencies for the airport and some
media/television ones. Figure I can lock out the control channel if
I just want to scan everything else.
6: Common and itinerant frequencies: FRS, GMRS, MURS, etc.
7: My standard Ohio Travel bank. Wireless microphones, OSP and law
enforcement statewide as well as some other mutual aid and emergency
type frequencies, including 800 MHz.
8: Ohio MARCS tower sites in the immediate area, I have the
talkgroups pretty much set for this bank as well. Not expecting to
hear much, but I need to include this. Also I have the 390 MHz NBFM
ISR frequencies (the military's FRS) in this bank.
9: And finally some previously known and/or reported frequencies for
the military performers (Leap Frogs, USAF F15/F16, USN F14/F18).
Will provide another starting point at least.
As for the show itself, I will be there Saturday for sure, and
possibly Sunday as well. We also have a proposed meeting if anybody wants to get together and cross check frequencies and any other updated information we may have discovered. Under the right wing of the the C-141 is the meeting place if accessible. Times for Saturday will be around 11:00am and 2:00pm as long as it is not in the middle of an interesting performance. Looking forward to seeing other folks there!
Jeff
