Daytona 500
Hello. I have a couple questions I am hoping anyone on here can answer for me.
I will be going to the Daytona 500 Sprint Cup Race on the 26th. This will be my first time going to the race in Daytona.
I am just wondering if anyone on here has a updated or up to date frequency list for all of the drivers for this race including the CTCSS and DCS Tones they use. So I can get my PRO 96 set up and have it ready to go with these frequencies and tones in it for the 26th.
Also since this is my first time going to the race in Daytona. Is there anything else to listen to at the track as well, like: EMS, FIRE, etc. And would these other things to listen to be Analogue, Digital or (TRBO Which my scanner cannot do). Let me know.
I will be waiting for any replies to this post.
Thanks.
Coolguy
Forts
Ontario, Canada
Pretty much any list from last season (such as this one: Jayski's® NASCAR Silly Season Site - Scanner Frequencies/Equipment Links) will still be current. While the drivers may move around from team to team, the frequencies typically stay with the car. Also, being the 1st race of the year pretty much the most recent list will be from the last race of last year. Depending on how much time you have before you go, I would check around after the Bud Shootout and during Speedweeks to see if anyone posts any updates.
As far as other stuff to listen to, I would imagine most of the track workers (concessions, parking, security etc) would all be analog but you would likely just have to search those out. I would start with the UHF range and work my way out from there. From the tracks I've been to in the past I usually find all this stuff in the 440-470mhz range. EMS & fire may be on whatever frequencies they typically use for that area, so I would check out the database page for Daytona, and do a search in the Florida forum for Daytona as well.
The track officials pretty much all use MotoTRBO except for race control and timing & scoring. Their frequencies are on the link I posted above.
K4IHS
Charlotte, NC
Another option is to get your scanner programmed at the track. There are usually 2-3 booths that rent equipment and they also will program your scanner with the updated frequencies being used. I had my scanner programmed in Charlotte last year... the cost was a donation to a jar to a local charity. Even if they charge... it will be cheap. Also... make sure you have a good comfortable headset because it's very noisy at the track. Wear it for awhile before you go to make sure... :)
Forts
Ontario, Canada
Agreed about the headphones. Make sure you have a set of 'racing' headphones. Regular ones simply wont cut it at all.
Yup I already have the headphones from last year when I was in Michigan at the race there that I bought. So I am all set to go with that, lol.
Ok and if I did that and I did decide to get it programmed there. They will program any scanner including a PRO 96 and when they program it, will they just program it with the frequencies or will they include the CTCSS and DPL/DCS Tones they are using. Also would they program in all of the frequencies along with the: OFFICIALS, PACE CAR, and all the things like that, that are monitorable and can listen to. Let me know.
Also would anyone happen to know any of the CTCSS/DPL(DCS) Tones the Drivers and all of the other things around the track use. If anyone does, I can finish setting up my PRO 96 Daytona file with the tones for these things I mentioned and update any of the tones I got from Michigan last year, incase for some reason some of the tones changed for certain drivers and just incase I don't get around to getting it programmed at the track. I would appreciate it, if anyone knows the tones and can either post on here or send me a .p96 file with them or however anyone wants to do it. Let me know.
Thanks again
Forts
Ontario, Canada
Just Google NASCAR frequencies, or search on here. You will find lots of lists with the tones.
tvsmike
Shawnee, KS
The absolute best place to get the most updated frequencies is at the track and also at Racing Electronics - Welcome!. They are at the track as well, and they can program your scanner, but it will cost you $25. If you get the frequencies online, its only $10 and plus you will get a nice clean PDF of all the frequencies to print out. Also the $10 will get you access for the entire year. So whatever changes throughout the course of the season you'll always be up to date. Best $10 bucks I spend all year.
I'm a season ticket holder at Kansas Speedway and now with 2 cup races a year, I really use the heck out of the scanner at the track. Over the last few years I've had a Uniden BC92XLT and had good luck with it, but finally decided to get serious at the track and also make my life easier and picked up an SC230 and now with the Racing Electronics subscription, they offer programming files for the SC230 that I can load directly into the scanner via software and a computer hookup and its good to go.
So I think its worth the 10 bucks for sure.
Can't wait for Daytona! Have a blast. Wish I was going.
-Mike
Ok. Thanks for the info. And yah this will probably be my only race I will be going to. Since we live quite a ways from the nearest track which would be Michigan. So the next race I might go to again sometime will probably be Michigan.
And yah since I brought my PRO 96 with me when I went to the race in Michigan last year and the year before. It worked great for what I needed it for and to get the Tones for the drivers and that while I was there. So came in handy that is for sure.
So I am looking forward to going to the race in Daytona and my first time there and also my first time to see the first main race of the season to kick things off. And looking forward to seeing some good wrecks or just some wrecks anyways compared to Michigan when we were there last year and the year before where there was really no wrecks at all. So wasn't that much excitement there without a few wrecks.
So otherwise I have everything all set to go. So I will use the frequencies I got from the internet along with the tones and see if I need to make any changes with any of the freq's for the drivers or the TONES when I am there and go from there.
So if anyone else wishes to help me out with any other freq's I should know about or want to share the TONES for the drivers with me. I would appreciate it.
I will be waiting for any replies to this post for anyone who wants to reply.
Thanks again.
patchman
fort worth
Daytona
Hello,
Here is what I have in my files for Daytona. You can get the NASCAR freqs on line or at the track.
Hope this helps.
Frequency*Tone* Description*
464.5250 Race Officials
464.9750 85.4 Race Officials
464.9750 Race Officials
464.6750 Race Control-Tac 1
464.8250 Race Control-Tac 2
461.0875 Track Safety-NASCAR
461.4750 243 DPL Security?
461.5750 Operations
461.6250 Unknown
461.7000 023 DPL* Unknown
461.8500 423 DPL Gates
464.2000 162.2 Racing Radio
464.3125 Speedway Safety Services
464.5000 423 DPL* Wrecker/Fire Unit Dispatch-NASCAR
464.5875 Tickets
464.7750 432 DPL* Gates/Security/Ticket Booths/Maintenance
464.9000 NASCAR
Scott
Ok. Thanks for those. I will add them to my p96 DAYTONA 500 file and try to listen to wutever I can when I am there, lol.
Thanks for all the help. If there happens to be anything else I should know about before the race on the 26th, let me know.
Otherwise thanks again.
aquadan005
Eastern Mont. Co. PA
Primary, secondary and tertiary frequencies from last year. Most of the popular ones should be the same. However drivers like Khane and Martin who changed teams will be different. Have fun!!
1 Jamie McMurray 466.6875 457.6000 464.9300 451.3300
2 Brad Keselowski 466.2125 * * *
4 Kasey Kahne 452.0875 * * *
5 Mark Martin 468.2125 467.0375 469.4875 469.4900
6 David Ragan 460.9500 466.7500 468.5625 463.4000
7 Robby Gordon 463.6500 469.4500 466.3400 461.8500
9 Marcos Ambrose 456.8500 * * *
10 Terry Labonte 461.5125 * * *
11 Denny Hamlin 467.4750 462.4250 466.0125 *
13 Casey Mears 464.3750 * * *
14 Tony Stewart 469.7375 469.1375 464.6375 466.5000
15 Michael Waltrip 451.4375 * * *
16 Greg Biffle 468.4500 465.0250 462.0250 461.3500
17 Matt Kenseth 458.4750 462.4500 463.7100 463.9500
18 Kyle Busch 467.4500 462.5000 451.3000 451.3500
20 Joey Loganao 462.5250 462.4750 451.4000 451.5000
21 Trevor Bayne 452.2000 452.0125 461.7250 451.3750
22 Kurt Busch 451.8250 * * *
24 Jeff Gordon 467.0625 465.8625 468.2125 469.4875
27 Paul Menard 457.7500 * * *
29 Kevin Harvick 469.0125 462.0250 466.0250 463.2250
31 Jeff Burton 468.5750 468.6000 464.0750 468.2500
32 FAS Lane Racing 462.2500 * * *
33 Clint Bowyer 469.6375 469.3750 468.2500 464.5875
34 Travis Kvapil 467.1125 * * *
36 Dave Blaney 461.6625 457.0875 * *
37 Robert Richardson 463.3125 461.8375 * *
38 David Gilliland 467.8500 * * *
39 Ryan Newman 469.1375 466.5000 464.6375 469.7375
42 Juan Pablo Montoya 466.1000 452.7000 425.7000 *
43 A.J. Allmendinger 462.8578 462.7625 456.5250 462.7650
46 J.J. Yeley 452.1750 * * *
47 Bobby Labonte 457.5375 461.9375 * *
48 Jimmie Johnson 455.8625 452.2375 451.9875 466.3375
55 HP Racing 467.4375 * * *
56 Martin Truex Jr. 452.1125 * * *
60 Todd Bodine 464.5265 *
64 Derrike Cope 460.9250 452.6500 * *
66 Jason Leffler 461.7625 462.7375 * *
71 Andy Lally 453.6625 453.1625 * *
77 Steven Wallace 464.1375 * * *
78 Regan Smith 452.2625 466.0250 * *
81 Whitney Motorsports 456.6750 * * *
83 Brian Vickers 458.1125 * * *
87 Joe Nemechek 464.2875 468.8375 * *
88 Dale Earnhardt Jr. 462.0625 466.7875 * *
90 Scott Riggs 458.3750 * * *
92 Brad Keselowski 457.0875 * * *
97 Kevin Conway 457.4125 * * *
99 Carl Edwards 466.2750 468.8625 466.8625 *
00 David Reutiman 463.2125 469.1125 * *
09 Bill Elliott 469.3125 460.7375 * *
* NASCAR 1 & 11 461.2000 * * *
* NASCAR 2 & 12 464.6000 * * *
* NASCAR 5 & 15 451.2250 * * *
* NASCAR 10 451.5750 * * *
* RACE CONTROL 461.2000 * * *
* RACE CONTROL B/U 464.6000 463.6250 * *
* SAFTY/FIRE 451.2250 * * *
* NASCAR Weather 467.8500 * * *
* MRN Radio 454.0000 * * *
* PRN Radio 454.0000 * * *
* ESPN 450.6250 * * *
* ESPN/ABC 450.1750 450.1250 450.1375 450.1000
* ESPN/ABC 450.2750 450.6875 * *
* TBS 462.0250 462.0500 450.7625 455.5875
* TNT 450.5875 * * *
* FOX 450.2375 450.3000 450.0375 *
* SPEED 450.1125 * * *
* ROWDY Pre-Race Show 454.5000 * * *
* ROWDY Classic Interviews 454.7000 * * *
Yup, was there and had the file I put together from the freq's I got off of the internet that people told me to check and what I found myself and obviously didn't hear too much since it was raining, lol. And 2morrow it looks like the weather will be the same again, unless it really changes by the morn. Fingers crossed. If not, then I am out of luck. The main thing I got to go there and see Daytona for my first and probably only time.
But if the weather really changes 2morrow morning and holds off, then we will see if I will come up with any other channels, I couldn't get 2day.
