Radio Shack Pro-164 Firmware
jgriffter
I ordered the Radio Shack 20-047 cable. The old original cable sold by RS. Was specifically noted in the RS firmware instructions as the cable needed. Hopefully it will work.
jgriffter
Reporting back to the group and again thank you for all your assistance.
I received the old RS 20-047 cable and had a chance to try the firmware upgrade. All went well! Moved from firmware 1.02 to 1.10 (last firmware). The old RS cable worked without a hitch. The radio is working as it should. Thanks again for the help on this. For whatever reason, the first cable I bought would update frequencies but not update firmware. The old RS cable does both.
jgriffter
Sure, this is it.
After i bought it initially i went back and looked back at the description and it does mention it does not do firmware. I must have missed that - I've had problems with cables that didn't work at all, or driver discrepancies, but never a cable that only worked for certain things.
By the way in doing research I believe the difference between the RS 20-047 and 20-056 is that the 20-047 is an older cable with the orange clear circuit board box and two LEDs vs the 20-056 is an all black molded single LED cable. Apparently they are the same cable - the 20-056 is a newer version that looks more like the connection cables we buy today.
tvengr
Well Known Member
Baltimore County, MD
I noticed that about the firmware updates also. I have 2 genuine Radio Shack 20-546 cables. I have never had firmware update problems using those cables. They work for the PRO-96 which is 4 years older than your scanner. I haven't had the opportunity to try them on a PRO-164. I will have to make a note not to use that cable. Glad to hear you got the scanner updated. I have ARC300 software if you need any programming help.
