DC Power Supply
ArloG
Personally I would steer away from any switching power supply for a radio. A linear power supply or vehicle battery is really the best way to go.
Solar inverters or any inverter for that fact just introduce noise. Something you really don't want for dxing. Now. If it's VHF, UHF you operate then perhaps. I do like Meanwall power supplies. They make very nice ones. From my industrial world experience, the medical grade ones are much quieter than their everyday off the shelf variety. But they are switchers.
Icom dropped the ball big on at least the IC-R8600 by selling the AD-55NS power brick and the matching speaker with the same ps in it.
Noisy as hell. It obliterates any chance of receiving NAVTEX and is simply full of hash. For weak signals, a disaster. Not so much when you get up there in the ps band or when using FM.
Now. I got nothing against charging my LiFePO battery bank with the Noco charger after a period of radio usage. Or charging while sing them with a linear charger.
The subject of 13.8 VDC vs 12 VDC comes up. Radios that use specified 13.2 or so voltages will run just fine in 12 volts. Look at the specs sheet. Especially if you transmit.
Usually that 13.2 volts will be passed through an internal set of regulators and dissipated as heat if using linear regulators inside the radio.
So 12 volts may be the hot ticket. A 13.2-13.8 volt fully charged battery will give you leeway of radio use until they discharge to around 12 V.
Yeah.....
And. During the hurricanes in Florida when the juice was off for a week. I used my laptop with an 18 VDC power brick on 12 volt batteries. It worked just fine. That's when I made my first buss bar and started cutting wall wart cables to run my fiber modem and router and stuff.
Sorry for the rant. If you have a coin to toss and you make a choice of switcher vs linear supply for your rigs. Choose linear.
On a side note. If you look at the schematic of most any smps. The output filtering consists of a simple small choke (inductor) a resistor, and a bulk capacitor. Detail is given more on filtering back emr to the mains than rf, switching hash on the output. Across the board.
littona
Super Freq
Council Bluffs, IA
Keep in mind, 13.8V is also vehicle power. You can source a lot of parts from automotive places. You can get some really nice fuse panels, illuminated switches, ground distribution blocks, etc. I personally like to use 2-wire trailer wiring connectors on my lower amp radios, as they can only be plugged in one way, they're pretty solid, and they're cheap.
jazzboypro
Laval
Personally, i would buy something more powerful than your actual need. Don't skimp on the power supply.
KMG54
Easley S.C.
My 400 watt system charges while I am at work, the rover 40 amp controller shuts down at night. I have about 4000 Amp hrs running at 13.8 with no solar charging at this time of night, so no noise.
rocky28965
Otago, NZ
I finished up buying a QJE PS30SWIV power supply and an automotive fuse block to connect it all up.
Haven't got it connected up yet.
Waiting for my IC-R8600 to arrive.
It's a lot deeper than my other radios, so will have to modify my rack to accommodate it.
rocky28965
Otago, NZ
One of my radios is a Uniden UBC370CLT desktop scanner.
I'm wondering if it would handle 13.8 volts.
rocky28965
Otago, NZ
Well, I guess there is only one way to find out for sure.
I've nearly finished modifying the rack.
I'll start wiring it all up tomorrow.
KMG54
Easley S.C.
Am I crazy for going with deep cycle flooded lead acid batteries? Watching you tube, must have lifepo batteries.. I am up to six AC Delco deep cyles group 27 batteries now for the cost of 1 and a half Lipo's. And I am not strip mining the earth to have them. Each are 100 amp hours, seems like a better deal to me. I did realize my typing is not the best when 400 amp hours came out as 4000 in my previous post.
KMG54
Easley S.C.
I did a test run tonight, well when I got home and ran my frigde and ceiling fans along with this PC with no issues.
No, you are not.
The LiFePO batteries make sense if you need a lot of power in a really lightweight package. They have some nice features, that is for sure, but the high price isn't worth it for most. Some of it, as I'm sure you have seen, is about bragging rights. "I've got the best and unless you do exactly as I do, you are less of a human being".
I run some very large battery systems at work, 1800ah @ 48 volts DC at multiple sites. These battery systems are the size of a couple of large refrigerators. These are for critical loads. We also have some large 'whole building' UPS systems that support a 911 center. A bunch of public safety repeaters and other systems.
All of those are running large gel cells. They work just fine, they are cost effective, and they are well behaved. I'm also not blowing tons of taxpayer dollars on bragging rights. I cannot make a financial or technical case for replacing all those gel cell plants with LiFePO batteries.
If the batteries work for you, that's all that matters.
KMG54
Easley S.C.
I'm also not blowing tons of taxpayer dollars on bragging rights. Love it! :p
:p
