DE TRS System
BillQuinn
Okay I have a few questions about talkgroups and frequencies and trunking sites.
1. One my PSR-500, I have KN-CMD (2320) programmed under only the Kent County site. Is KN-CMD (2320) repeated on the NCC Site?
2. I usually hear WPD units on WILCOM ask eachother to go to TAC-C. Whenever I switch over to TAC-C on my scanner, I don't hear anything. Is it some sort of simplex channel or what? I have the TG ID# as 27856. Is that the correct TG ID#?
3. I see that there are 2 other IR sites in NCC, in addition to the main NCC site, Winterthur and Hockessin. I know where Hockessin is but where is the Winterthur IR site located? What units have been heard using the Winterthur and Hockessin sites?
4. Are TALK 1 and TALK 2 used much? Are they simplex channels or repeated channels?
That's All
Thanks.
de784
Delaware
Ncc
Negative
It's full time encrypted
This is where Winterthur is Located http://www.radioreference.com/apps/db/?cs=WPWM309
Looks like they use another cc for NCC
For Sussex and Kent used for Fire Ground Operations can't speak for NCC also used when trs goes down
That's All
Thanks.
Hope this helps
Audiodave1
Chadds Ford, PA
Actually, Kent Command is repeated on the NCC system full time.
Regarding Talk, They are simplex only.
Seldom used but have been heard up here with non business talk.
Dave
de784
Delaware
Ncc
Thanks Dave for clearing that up I checked my scanner last night and I don't have the tg in for NCC so when I am up that way that's why I never hear it.
again
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Hey DE folks, thanks for this thread.
How about this scenario?
Gonna pass through (I-95) on the 26th and return on the 29th to/from Philly. For the 20 miles of travel, it appears the Winterthur site is all I need with a Wildcard in a PSR-500 and 600.
Also, the Wilmington system controls and a Wildcard since it too will be for near the same distance.
Or should I use select TG's for both systems?
Thanks,
Audiodave1
Chadds Ford, PA
Hello,
Just use the main system. It covers I95. The Wthr site is a really focused system for that general recreation area.
You should only need the DSP command, data and TAC groups. The TMC group(s) can be a great help as to traffic conditions. Pick the FD groups at your leisure.
If you will be taking I495 around Wilmington I would not worry about that system as they do not patrol the interstate to my knowledge. This system has a very small RX footprint.
Once you get to PA PSP VHF system, 155.505 / .850 to the airport then 155.670 / .910 (Base/Mobile) + 155.460 car-car.
Dave
fmon
Eclipse, Virginia
Thanks guys.
Dave, those PA freqs will be very useful.
Is 495 best route to I-95 exit 8 in Philly? Streets & Maps and Garmin both route me that direction.
N
N_Jay
Guest
Thanks guys.
Either 95 or 495 will work.
Don't forget to use 896 and Elkton Rd. to go around the DE/MD line toll.
BillQuinn
Tac C
What about WPD TAC C? I always hear cops say "go to tac c" or "c". When i go to TAC C, I don't hear anything. I have the ID as 27856. whats wrong?
h8tdigitalradio
Six Feet Under
As previously mentioned, WPD Channel/TAC C is Full Time Encrypted. Thats whats wrong with you scanner. It doesn't or can't monitor encrypted communications. If you want to monitor Channel/TAC C, you will need the real /\/\otorola radio.
73
Dave AKA The Tripzter
KB3JUV
Nashua, NH
73
And the encryption key!
