TIII Connect Plus LCN LSN
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I have LCN's assigned to each frequency, which i now understand that is incorrect. I hear the key up and about 1/2 second of voice, where i assume it is moving to a different freq & TS. I would assume if encryption was enabled it would be enabled at keyup before voice is transmitted.
I never give up on challenges like trying to get this working, but like i said if its encrypted, its done. I know pretty much everyone in here has alot more experience than me and please let me know your thoughts, abandon or keep trying until i see fully encrypted?
I trust that there is at least 50+ years of combined experience in here that i lack. If I find its fully encrypted i can submit to RR to update DB.
The only way you’ll know if it’s encrypted or fully encrypted is to get it configured
Remove everything from SDR trunk and add four separate simple DMR frequencies, the 856 and 857 ones. Play them all.
knightrider3002
Antenna Builder Hobbist
Hogansville, GA
as of now, messages and events, no mention of encryption
knightrider3002
Hogansville, GA
With no LCN/LSN frequencies entered, doing now!
knightrider3002
Hogansville, GA
@mtindor Set up a new channel as recommended. I really appreciate everyone's help here and will follow up after SDRTrunk runs tonight and hopefully establishes CC for the frequencies. Will report back in the morning to all if not encrypted and direct with DBA with logging if encrypted to update the DB.
mtindor
FMP24 PRO USER
Here is what i would do -- clear out everything you added in SDRTrunk.
1. Create an Alias List called "Hogansville"
2. Add a wildcard talkgroup
3. Add the possible PD talkgroup (5036)
4. Don't put funky description about RRDB or FCC licenses. That is useless information and serves only to confuse you or anyone you are asking to read your screenshots.
Then add four channels
- simple DMR
- ignore data calls
- ignore crc checks
- assign the Alias List of "Hogansville" to each channel
You are going to need to have an alias list with a wildcard at least if you want it to play anything.
mtindor
FMP24 PRO USER
- simple DMR
- ignore data calls
- ignore crc checks
one frequency per channel. Don't add all freqs to a channel like you have done. You'd only do that for a trunked system.
knightrider3002
Hogansville, GA
Thank you for babying me through this!!! I will definitely do this in the am, currently headed to bed EST.
Only clarification question, can you clarify your #2. Add a wildcard talkgroup, not sure what you mean.
Understand the below:
- simple DMR
- ignore data calls
- ignore crc checks
mtindor
FMP24 PRO USER
- simple DMR
- ignore data calls
- ignore crc checks
You would normally add a DMR talkgroup (like 5036 as suggested in screenshot). But you can also add a talkgroup range. If you look at my screenshot for Wildcard, I added a talkgroup range (you can see if you look at the full picture). that's a wildcard. If you have a talkgroup range setup that includes the min-to-max talkgroup number, that's a "wildcard" and so I call it a wildcard.
If you are family with more recent Uniden digital scanners, it would be like scanning a system with "ID SEARCH" set to on. Basically its going to play any and every talkgroup.
If you don't add any talkgroup to a playlist, it won't attempt to play any talkgroup. You can add just 5036, but that may not be the only active talkgroup. So add 5036 as "possible pd" as my screenshot suggests, and then add a talkgroup range and call it wildcard (as is shown in the picture where Wildcard is highlighted. If you are viewing hte full screenshot, you can see where it lists the talkgroup range for "wildcard" at the bottom.
knightrider3002
Hogansville, GA
System setup, running and off to work. Will let you know the results this afternoon. Thank you again, especially for your patience!!!
DaveNF2G
Latham, NY
Having used both programs, I would prefer to rely on DSD+ for investigating anything unknown. SDRTrunk is not reliable on systems where I already have all of the info.
CrewRest
Sarasota FL
I'll jump in on this thread, if you all don't mind. I running DSD+ FL. I've been using it for a while but never with Tier III until now. I have a Tier III system. Good signal with no errors. In auto it came up TIIInonStd[Auto](MOT) Site L8-6 DCC 8 RAS. There is nothing in RR to download in regards to this system so starting from scratch. I only have the CC for now. No TG's or RID's. The channel activity window only shows ? and CC. In the .networks file I have TIIInonStd, 8, "Publix Sarasota" in the .sites file I have TIIInonStd, 8, .6, "Sarasota" in the .frequencies file I have TIIInonStd, 8, .6, 0, 452.225, 0.0, 0
what should those files really look like?
mtindor
FMP24 PRO USER
Reference for anyone trying to help you -- the Publix license:
;dsdplus.networks
;protocol, networkId, systemName
TIIInonStd,L8,"Publix Supermarkets"
;dsdplus.sites
;protocol, networkId, siteId, siteName
TIIInonStd,L8,6,"Sarasota"
;dsdplus.frequencies
;protocol, networkId, SiteID, LSN, outputFreq, inputFreq, sortOrder
(really can't fill this out til you know the active freqencies AND LCNs)
ex:
TIIInonStd, L8, 6, <oddLSN>, <outputFreq>, <inputFreq>, 0
ex:
TIIInonStd, L8, 6, <oddLSN>, 452.225, 457.225, 0
Notice you still need to know the LSN.
Here are all the freqs on the license for Sarasota:
451.475
452.225
461.175
461.775
463.300
464.8125
You usually at least need to discover one LSN in order to determine if its using a bandplan (typical) or if its using custom LSNs (can happen).
Why don't you just sit, parked on that 452.225 control channel, for a day or two. Watch the Channel Activity Window in DSDPlus and note EVERY LSN / Ch ID that shows in the Channel Activity window and post it.
If you want to test a possible frequency list for dsdplus.frequencies:
TIIInonStd, L8, 6, 1035, 451.475, 456.475, 0
TIIInonStd, L8, 6, 1155, 452.225, 457.225, 0
TIIInonStd, L8, 6, 2587, 461.175, 466.175, 0
TIIInonStd, L8, 6, 2683, 461.775, 466.775, 0
TIIInonStd, L8, 6, 2927, 463.300, 468.300, 0
TIIInonStd, L8, 6, 3169, 464.8125, 469.8125, 0
The LSNs I listed in dsdplus.frequencies may not be right, but try them.
And if you park on the control channel and watch the Channel Activity window when it is active, if you see one or more of 1035/1036, 1155/1156, 2587/2588, 2683/2684, 2927/2928, 3169/3170, then you know my calculations for dsdplus.frequencies is correct. If the numbers in the channel activity window are different, post them so we can tell you what you need to change.
CrewRest
Sarasota FL
dsdplus.networks
dsdplus.sites
dsdplus.frequencies
ex:
ex:
451.475
452.225
461.175
461.775
463.300
464.8125
TIIInonStd, L8, 6,1035,451.475,456.475,0
TIIInonStd, L8, 6,1155,452.225,457.225,0
TIIInonStd, L8, 6,2587,461.175,466.175,0
TIIInonStd, L8, 6,2683,461.775,466.775,0
TIIInonStd, L8, 6,2927,463.300,468.300,0
TIIInonStd, L8, 6,3169,464.8125,469.8125,0
Mtindor! U Da Man with the info to get me started! I'll let you know how I make out. I did put it into the SDS200 to analyze and it gave me an LCN of 8, which I don't think is correct. I used LCN/LSN calculator an and it came up with 45. I'll do some experimentation starting with your suggestions. Thanks
mtindor
FMP24 PRO USER
Yes, the most crucial part is:
1. park on the current Control Channel
2. monitor the Channel Activity window
As voice calls occur (or private calls) the Channel Activity window will display LSNs (channel ids, ch id, ch whatever). Those will be the LSNs used in the dsdplus.frequencies file and are matched to specific frequencies.
When you see one or more of those in the Channel Activity window, post them -- so we can determine if everything needs to be recalculated (i.e. because my calculations may have been wrong).
Don't try to just trunktrack with what I gave you. Don't put anything in dsdplus.frequencies yet. First get the LSNs from the channel actiivity window to see if the LSNs in the Channel Activity window match the LSNs I mentioned in my dsdplus.frequencies stuff I posted. The LSNs will be pairs -- like 1035 and 1036, 1155 and 1156, or some other pairs altogether. Each odd number LSN in the channel activity window will have an even number LSN one number high as its pair.
mtindor
FMP24 PRO USER
@CrewRest
NOTE: If you add the dsdplus.frequencies that I posted BEFORE you make note of the LSNs in the channel activity window, you might confuse you, me, everyone else, and DSDPlus and it may not trunk and it may show frequencies in the channel activity window that confuse you.
So please just capture/post some LSNs from the channel activity window into a response in this thread so that we can determine if I gave you the right dsdplus.frequencies stuff.
A simple screenshot of the Channel Activity window with LSNs listed in it will suffice. Don't paste the image into a post, but rather add the image as a file people can click on using 'Attach Files"
mtindor
FMP24 PRO USER
Observation #1 I now have a Ch and TX on the activity window!
If you added me DSDplus.frequencies stuff, you would. BUT, it may not be correct. That is why I said don't add them. Leave DSDPlus.frequencies blank, and park on teh control channel and what for voice calls / private calls so that the Channel Activity window fills with proper LSNs. IF the LSNs showing up in the Channel Activity appear to match the ones I gave you for dsdplus.frequencies, then you are probably good to add them. If they ARE NOT, then you definitely don't want to add what I gave you and instead you want to post what's in the Channel Activity window.
FYI, looks like Publix probably has at least 8 sites on that L8 Capacity Max system
WRPW595 McLeansville NC (Guilford)
WQYM848 McCalla AL (Jefferson)
WQCR773 Lawrenceville GA (Gwinnett)
WQCR773 Atlanta GA (Fulton)
WQCR773 Dacula GA (Gwinnett)
WQXN796 Orlando FL (Orange)
WQXN796 Sarasota FL (Sarasota)
WQUD266 Orlando FL (Orange)
CrewRest
Sarasota FL
Here is a sample of the log;
2025.02.18 7:43:37 +DMR slot2 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 B; Networked; Registration req'd
2025.02.18 7:43:37 SYS_Parms: SysCode=10.1000.00000110; Registration req'd; CSC=0
2025.02.18 7:43:37 +DMR slot1 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.02.18 7:43:37 +DMR slot1 BS DATA ERR1 DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.02.18 7:43:38 +DMR slot2 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 B; Networked; Registration req'd
2025.02.18 7:43:38 +DMR slot1 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.02.18 7:43:38 SYS_Parms: SysCode=10.1000.00000110; Registration req'd; CSC=0
2025.02.18 7:43:38 +DMR slot2 BS DATA DCC=8 CSBK ERR1/RAS Aloha SysCode=10.1000.00000110 B; Networked; Registration req'd
2025.02.18 7:43:39 +DMR slot2 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 B; Networked; Registration req'd
2025.02.18 7:43:39 SYS_Parms: SysCode=10.1000.00000110; Registration req'd; CSC=0
