TIII Connect Plus LCN LSN
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Here is a sample of the log;
2025.02.18 7:43:37 +DMR slot2 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 B; Networked; Registration req'd
2025.02.18 7:43:37 SYS_Parms: SysCode=10.1000.00000110; Registration req'd; CSC=0
2025.02.18 7:43:37 +DMR slot1 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.02.18 7:43:37 +DMR slot1 BS DATA ERR1 DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.02.18 7:43:38 +DMR slot2 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 B; Networked; Registration req'd
2025.02.18 7:43:38 +DMR slot1 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.02.18 7:43:38 SYS_Parms: SysCode=10.1000.00000110; Registration req'd; CSC=0
2025.02.18 7:43:38 +DMR slot2 BS DATA DCC=8 CSBK ERR1/RAS Aloha SysCode=10.1000.00000110 B; Networked; Registration req'd
2025.02.18 7:43:39 +DMR slot2 BS DATA DCC=8 CSBK ECC/RAS Aloha SysCode=10.1000.00000110 B; Networked; Registration req'd
2025.02.18 7:43:39 SYS_Parms: SysCode=10.1000.00000110; Registration req'd; CSC=0
That's odd. I wonder if you are actually parked on a Data-only channel. CapMax systems can and often do have dedicated data channels. And on those channels you'd never see a call.
If it truly is a control channel you are on and you don't see neighbors, I would simply guess that whomever set up the system decided that having the neighbors broadcast is fairly senseless since you couldn't really seemlessly roam between sites sometimes hundreds of miles away.
You should check every frequency associated with the license that is an FB# frequency, and see if you can find any others that appear to be 24/7 active.
Otherwise, if that's the only one, it looks like they really just set it up but don't have it operational for staff at this point.
In the main DSDPlus window (Event Log Window) you should at least see some GROUP and PRIVATE calls. I'm guessing you see none of that.
Mike
CrewRest
Sarasota FL
Mike
I'll go thru and check all the Fred's. No, Private or Group calls.
mtindor
FMP24 PRO USER
Looks like you:
a. put all of the applicable stuff in DSDPlus.Networks, DSDPlus.Sites
b. put non-confirmed data in DSDPlus.frequencies (I'm basing this on seeing 1155 in Channel Activity window)
Did you in fact put my nonconfirmed stuff in DSDPlus.frequencies? If so you should take it out for now. That isn't why you aren't seeing traffic though. Looks like there simply is no traffic to see / no traffic occurring.
That looks like it should be a control channel, but I'm pretty sure I see the same thing on Data-only channels. I'm going to check a local Data-only channel and see what it shows.
I can confirm that my Data-only channel shows similar data in the log and info displayed at the bottom of the Event Log window
So I have a feeling you are on a Data-only channel (although I wouldn't necessarily be a 24/7 channel). Definitely should look around at all the other channels and see if you can find another one that is 24/7 for that site.
CrewRest
Sarasota FL
Looks like you:
Thanks for sticking with me on this. No, I didn't put anything except 1155 and 452.225, if I put nothing in for the LCN/LSN or a 0, I get ? and no freq shown just "CC", but I left all rest out. I put all the other stuff into Networks and Sites. I took a look at the other FCC freqs for Publix and came up with nothing. I'll keep looking around.
lwvmobile
DSD-FME
This does appear to be a control channel for CapMax if you ask me, both slots are filled with nothing but CSBKs, particularly the Aloha. I'll venture a guess that you don't see any call activity or anything really, is because there isn't any yet. Either the system is so not busy, you aren't catching any activity, or its not fully operational yet.
