Dead BC996T ?
blantonl
Founder and CEO
Dallas, TX
Hey folks,
I updated the firmware in my BC996T today. After the update - all was working fine.
I come back in the room later in the afternoon - and the radio is dead and just sitting at a blank lighted screen. I power off the radio, then back on - nothing - no lights or anything on the display.
I removed the power from the back, then plugged back in, and powered up - and I briefly see a distorted message that says "Memory Clear Please Wait" - then nothing.
I've tried the 2,9,Hold keys on startup to no avail. Any ideas?
spooney
Indiana
I would try the update again. Did use use the current Update loader program BC_VUP installation program from Unidens website ??
blantonl
Founder and CEO
Dallas, TX
I tried that - it doesn't even want to go into firmware update mode.
hoser147
Grand Lake St. Marys Ohio
Man that sucks. Ive been wanting to get a new digital and thought I had it somewhat narrowed down. To the Uniden or the GRE. But after reading several posts seems like the Uniden 996 has more than enough bugs. And the GRE hasn't been in the field long enough with the newer models. Hope ya can get things worked out Lindsay its more than frustrating when ya have problems as you got. Guess Im going to put off things longer and see what happens. Good Luck Hoser
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
My suggestion may not work due to your description of your issue but it is worth a try. Unplug the power leaving adapter plug attached to unit. Turn unit on. Hold the L/O and 6 Keys while plugging wallwart or whatever you use to power unit and see if the unit returns to Firmware Update Mode or Backlight screen.
HTHs
73
Dave AKA The Tripzter
spooney
Indiana
And re-set (hold 2-9-HOLD/RESUME keys as you power on) doesn't work either?
N9JIG
Sheriff
Moderator
Far NW Valley
Check the ribbon cable that goes to the display daughter board. These tend to work loose and cause a blank display.
I had a similar issue with a BC15, I re-seated the ribbon cable and all was well with the world again.
blantonl
Founder and CEO
Dallas, TX
Yea - no joy... I think it might have died. It's been super dry here in San Antonio and static electricity has been rampant - I don't recall actually "killing it" - I just came in the room and it was at a blank lighted screen - powering off the radio resulted in a dead radio after that. I had just happened to have updated the firmware that morning..
Ugh.
Dubbin
Findlay Ohio
Ugh.
Well that blows chunks... You may want to shoot a PM to Paul to see if he has any ideas.
Nitsud
Hopefully its under warranty or something??
Its probably not a good PR idea for uniden to not get this fixed for the owner of this site
Dubbin
Findlay Ohio
Well I would hope they would show the same respect to everyone who bought a product from them.
