Good question. CBC wouldn't work given the unreliable nature of data over radio. If you lost a whole block - every block that followed would also be lost because decrypting depends upon correct data for the current block and all previous blocks.Radi0 said:What I meant was, do the radios use ECB, CBC, CFB etc...
I agree.lots of layers in this little project, too many...
Radi0 said:I am able to get what seems like a 10 second transmission... At first shot, sounds like a quick sentence, then 2 longer phrases...
Radi0 said:Here's what I have for timing on the sentences:
1, about 1.4 seconds,
2, about 2.7 seconds
I believe this is the sentence you posted:
"They can be modified into other puzzles that can be even more challenging."
3, about 6.1 seconds
Total, close to 11 seconds of transmission.
Cheers,
Casey
Radi0 said:Still unclear, but getting better!!!
Patterns are starting to emerge. I've been experiementing with error correction/decyrption
I think I have isolated the voice traffic.
I'm probably NOT going to get to a clear message fully, I just don't have time... I've spent too much time already. ;-)
It goes to show you that even if you CAN decrypt a message, by the time you do, its lost it value.
But it was definitely worth a try!!!
Cheers,
Casey
N_Jay said:The point is (AGAIN) . . . . . .
TEXT:
You could try a key and run the file, if you get lots of invalid ASCII characters, try the next key. all automatically at computer like speed.
This will probably sort out all but a few false positives.
Fast process, computer intensive.
AUDIO:
Try a key and run the file, search the audio for some very basic pass/fail test.
THEN listen to LOTS of false positive audio samples until you hear a voice.
SLOWWWWW Process, human intensive.
GET IT!!!!!!!:roll:
Xitium said:You could use some ASR program it wouldn't be that hard, it would not be as fast as scanning text but it would allow you to remove some of the human effort
rescue161 said:Dude, you are WAY off. That was a text file that they decoded.
Please don't post things like, "In recent years, the cryptography community repeatedly demonstrated DES's limitations. One such demonstration was a January, 1999, assault involving a combination of 100,000 networked PCs and a $250,000 computer built by the Electronic Frontier Foundation (EEF). It decrypted a DES-encoded message in 22 hours." because that was a TEXT FILE!!! NOT AUDIO!
Do me a favor an post MY audio in the encrypted file to prove the masses wrong.
Even if it is after the 1 week period, there will still be a "prize" so to speak.
Unitrunker said:3. I threw together some code to slice the waveform into a 12000 bit per second stream. Bit phase is inferred from +'ve and -'ve transitions through zero with some damping for noise. Bit level was determined by mid-sampling (sampling the waveform at the time believed to be the middle of a bit).
I already had code to do this ... (for Motorola and EDACS trunking) ... so it only took minutes to throw this together.
-rick
