Delete a Live Audio
FPOWLD
Westland, MI
How do you delete a live audio that you no longer want to listen to. I have five systems but don't want one of them.
QDP2012
Some steps:
  • In RadioReference, login at the very top of the screen, into the Login that lets you see your main RR profile.
  • After logging in, click on your user-id at the very top of the screen. It should take you to the screen called "Your Account"
  • On the "Your Account" screen, you will notice the "Account" tab is active.
  • Click on the "My RR" tab.
  • There are several subsections on the "My RR" tab. Scroll down (to the bottom of the screen) to find the list of audio feeds.
  • Find the (un)desired feed in the list.
  • On the far right of the undesired feed's row, click the checkbox in the "Del" column.
  • Scroll down to the bottom of the list and click the "Update" button.
This might not be the exact step sequence, but it should be close enough to get you started. (Since Broadcastify hasn't fully split from RR, it will redirect you to RR anyway.)
Hope this helps,
