VM5000 Nuisance Delete
GraniteScanner
P25 or BUST
Merrimack County New Hampshire
Good Moring,
I am having a heck of a time trying to get the Nuisance Delete feature to work on my VM5000. When I assign a button to Nuisance Delete in Armanda the option is filled in orange. In Armanda this indicates that this option is not available. I have checked the following already:
  1. Nuisance Delete is enabled in the conventional system(s).
  2. There is a scan list assigned to the zone.
  3. Each channel is a member of the desired scan list within the zone.
When a scan is enabled on the radio and I press the assigned button, the screen shows 'Unprogrammed'
I think I have checked every single menu and option, perhaps there is something i' missing?
otobmark
NC
I was hoping someone knowledgable would answer. The VM5k is NX5K hardware with Armada firmware. I do not know how much overlap exists but I have had "button" problems with NX version. From my aging memory some of it related to DTMF settings for the keypad. Some buttons did not seem to work and others did something entirely different than labeled in cps. Buttons can be used for ID's, direct channel, and more and can tangle up. Turn off DTMF on keypad. Again from memory, even if it is turned off it will still send dtmf from keypad if you do it while holding down PTT. None of this may apply to VM version of radio.
GraniteScanner
P25 or BUST
Fortunately I don't have the DTMF style keypad.
GraniteScanner
P25 or BUST
@GraniteScanner what version of Armada are you using and what firmware is in the VM5000?
Armda Version: 1.48.11
Radio Firmware: 8.20.5.42
I am also not using a template within Armada
Edit: I do see in error in the log. I would be absolutely baffled if the current firmware doesn't support this basic feature.
